Technical need help identifying rearend
Discussion in 'The Hokey Ass Message Board' started by hvychvy, Aug 1, 2014.
  1. hvychvy
    hvychvy
    I scored this rear at a salvage and can't figure out what it is. Small ford lug. 52.25" from flange to backing plate flange. 17 spline axles. Any info would be great.
  2. squirrel
    could be a 49-56 ford car rear? they look like that, with the funky ujoint, round drop out third member, small Ford bolt pattern, etc.
  3. hvychvy
    hvychvy
    Thanks,also its a 3:90 gear.what tag says.
  4. What does the pumpkin look like? HRP
  5. squirrel
    found this pic on the internets, for sale claiming to be from a 56 ford. Looks pretty close from what I can tell
  6. hvychvy
    hvychvy
    That looks like it.
  7. That axle appears to be a Spicer,looks like the one that was under my '54 Ford. HRP
  8. squirrel
    I don't think those are Spicer axles. Ford used Spicers on the wagons and trucks in that era, they have the removable rear cover, not the drop out center.
  9. You are absolutely correct Jim,My rear axle does indeed have the removable rear cover. HRP
  10. buttcropped.jpg ;)I cant idenify this one either.
    caseywheels likes this.
  11. Engine man
    Engine man
    from Wisconsin
    I'm certain that I could after a hands on inspection.
    willbe likes this.
  12. tommy
    tommy
    Looks like my 56 Ford sedan rear and U joint. If I can make a 32 Ford rear end live then this will probably work for me. I'm too cheap to buy a 9" Ford rear until it is necessary.:D
  13. This one is behind my shop that I pulled from a 1950 Ford,,looks like the one posted. HRP
