Projects Need help identifying an engine
Discussion in 'The Hokey Ass Message Board' started by DAGGER1120, Sep 21, 2019.
  1. DAGGER1120
    DAGGER1120
    So I have a 1964 f100. I was wondering if anyone can help me identify the engine inside it. It’s not a 292 Y block that’s all I know I’ve done a lot of research and the engine has no markings. The closest engine to it that I’ve found is a 302. Can anyone help me please. IMG_1390.JPG IMG_1389.JPG IMG_1388.JPG
  2. squirrel
    looks a bit wide for a 302, perhaps it's a 351W. There's a trick to telling which it is, but I forget, and it's hard to see the block/heads/intake junction, to make a guess, with all the stuff in the way.
    edit: maybe this will help
  3. Boneyard51
    Boneyard51
    Nailed it!
    Bones
    VANDENPLAS likes this.
  4. DAGGER1120
    DAGGER1120
    THANK YOU
  5. A quick method of determining between 302 and 351 is looking to see if the water pump is in the way of putting a socket on the lower thermostat bolt. If the water pump is in the way it's a 289 / 302, if you can put a socket on it it's a 351. Jim's way works too. :)
    DAGGER1120 and squirrel like this.
  6. squirrel
    I normally just look at it to tell, but pictures trip me up....harder to get the scale right from looking at a pic, than from real life.
    DAGGER1120 and Boneyard51 like this.
  7. hoop
    hoop
    I always thought the socket on the lower bolt on the thermostat housing was the way to tell. Then i ran into a 94-95 Mustang and T-Bird 5.0 . The socket went right on. Had me shaking my head for a while.
    Different water pump and possibly timing cover.
