We have a Borg Warner T10. It has a cast iron body and cast iron tail shaft housing. housing casting numbers 13 04 065 902 tail shaft casting T10K-7 1 groove on the input shaft Input shaft is 10 spline. The output is 16 spline. There is a number stamped by the cover WG 2242 Just can't seem to get the same answer twice! Thanks in advance.
Dimensions would help, especially the input shaft length and pilot diameter. Also, most T10s have casting dates cast into them. jack vines
build date is (G) 7th month, 22 day, 4 - 1974 2 - second shift. july 22, 1974 = WG2242 Single ring means 2:43 first gear. Mine is WJ 1032. with the same input teeth but a 27 tooth output. The 16 output sounds like an older unit but I don't think they used those number earlier. It should be one of the later first generation Super T-10's before the went to the larger counter shaft and aluminum case.
