Technical Need help, I think I got screwed
Discussion in 'The Hokey Ass Message Board' started by area351, Jan 13, 2019 at 1:17 PM.
  1. area351
    area351
    I bought this engine from a guy last night and I think I got screwed.
    It's been a while since I've built a SBC and was on the lookout for a 4 bolt main block which I found on Facebook Marketplace.
    After cleaning some of the surface rust and oil off today, it looks like this block had been sleeved in every cylinder.
    Is this block any good or should I just chalk it up and look for another?
    Why would someone spend the time and money to sleeve all 8?
  2. Paul
    Paul
    Editor
    If done correctly sleeves can be a better wall than the cast iron block, material, surface and thickness.
  3. Boneyard51
    Boneyard51
    Sleves, in themselves are no problem, If properly installed. What are your plans with this engine?
    Bones
    VANDENPLAS likes this.
  4. Paul
    Paul
    Editor
  5. area351
    area351
    No it's a standard 4.00 bore with 4 bolt mains and a cast crank. 217 heads which indicates a crate engine. It's been a while since I've done one of these (over 30 years).
    Are they even sleeves? I've only ever seen one sleeved block and a step was left in the bottom of the bore.
    Looking to build 350-400 HP for a project that I'm working on with an old tunnel ram.
  6. squirrel
    looks like they're all sleeved. I got a 454 once that was like that, it did fine while I had it.
  7. area351
    area351
    More pics. Someone has been grinding.
    Is this normal and I'm just worrying for nothing?
  8. lostone
    lostone
    from kansas
    Find a local machine shop and have them check it out, they'll be able to tell you more than we can with a couple pics.
  9. oldolds
    oldolds
    Interesting. A lot of work to save a basically nothing special engine. Nothing wrong with sleeves.
    Black_Sheep and VANDENPLAS like this.
  10. Like said above, done right no problem. What exactly are you worried about? One of my street Hemi blocks has 3 in it, no issues to date.
    The Wizzard
  11. area351
    area351
    That's what I'm trying to figure out. I'm not sure if it's sleeved. It just looks kind of weird.
  12. flatford39
    flatford39
    Those look like sleeves in your pictures but the naked eye in person is better than pictures. What do the cylinders mic out at???
    Like others have said nothing wrong with sleeves if done right. Regardless before you spend any money on it you need to have it magna fluxed at the minimum. Your machine shop should be able to tellou what you have.
    Ford in 39 had sleeved cylinders from the factory and I have worked on Alfa Romeos and they are sleeved from the factory as well. Actually pistons in an Alfa sit in a cast iron sleeve in an aluminum block and you can change out the sleeves with basic hand tools.
  13. BJR
    BJR
    from Minnesota
    Was that grinding on the bottom of the cylinders done so a bigger crank would fit?
    Engine man, flatford39 and Tim like this.
  14. 4wd1936
    4wd1936
    from NY
    If done right/well that is not a bad thing at all. Check them for size/taper with a dial and you might be pleasantly surprised. I do remember that being done with 305s to make them 350 but I never did understand why considering the expense. I quick check of the casting number, crank damper might answer that question. Good luck.
  15. Sleves are usually pretty clear. To tell you the truth when I first looked at this photo.[​IMG] It just looks like the witness mark left behind from the metal seal ring of the Old head gasket. I would have moved on and thought nothing about it.
    The Wizzard
  16. squirrel
    they are sleeves. The Target motors have a different block casting number, not 3970010, anyways. (except maybe the very early ones)
    It's been too long since I put in a sleeve myself....don't they work better if you don't bore it all the way to the bottom of the block? I forget :)
  17. I really don't see anything that would bother me. But it would be cheap insurance to have a machine shop check it out. Have them hot tank and magnaflux it for peace of mind. Have them tell you if anything's out of the ordinary. Money well spent as far as I'm concerned.
    lurker mick and flatford39 like this.
  18. manyolcars
    manyolcars
    Yes, there is step left in the bore for the sleeve to seat against
  19. area351
    area351
    That's the plan. I'm just baffled.
  20. Personally I have never done the actual install. Over the years I've been blessed with Top Cabin machinists to do that for me. The ones done for me to date have had a shoulder at the top that required a step bore at the Deck. The block was bored full length and sleeve cut to given length then after installed the Blocks have been decked. That may not be how all sleeves are done due to water jackets, thin decks or different manufactures of sleeves. In fact I have never had a sbc block done ever due to plenty good ones to start with. May not be the case today.
    The Wizzard
  21. G-son
    G-son
    from Sweden
    Just about every heavy equipment diesel out there is sleeved from factory, they run forever and when you eventually have managed to wear them out that makes it simple to restore them to as new condition again - unless you've had the block crack or rust away. So as others say, sleeves are not a problem when done right, quite the opposite.
    VANDENPLAS and Truckdoctor Andy like this.
  22. We have repaired blocks with holes in the cylinders by putting sleeves in, measure it and run it if it measures ok
  23. drtrcrV-8
    drtrcrV-8
    I've been told all Bowtie blocks are sleeved, & I know my 400 Bowtie block came that way. Show us pictures of both sides of the block, please.
  24. Budget36
    Budget36
    I think I recall my Dad calling them liners...lol.
    czuch and 1stGrumpy like this.
  25. conn.rod
    conn.rod
    from atlanta
  26. blowby
    blowby
    from Nicasio Ca
  27. Boryca
    Boryca
    from Detroit
    Could always be that the last guy planned on "big power" from that motor, and so had the cylinders sleeved rather than worry about potential off-center castings. Would also support the grinding for more clearance, Clarence.
    As many have said up above, sleeves ain't all bad. 350-400 hp likely wouldn't tax it.
  28. squirrel
    No. It's a completely different engine.
    Sent from my Trimline
    gimpyshotrods likes this.
  29. squirrel
    This is a 3970010 block, which is a normal 350 block, not a bowie block.
  30. firstinsteele
    firstinsteele
    What he said.
    Ben
