Can anyone help me? I search all data from 303cui olds rocket motor. I am also in search of any specify torques. greets from Germany, Marco
Here are some torque specs from a 1952 Olds shop manual. Connecting rod : 45-50 ft./lbs. Crank bearing cap no. 1,2,3 & 4 : 100 ft./lbs. Crank bearing cap (rear) : 140 ft./lbs. Cylinder head to block : 60-70 ft./lbs. Crank pulley bolt : 45-50 ft./lbs. Intake manifold : 22-26 ft./ lbs. Exhaust manifold : 18-22 ft./lbs. Flywheel bolts : 85-95 ft./lbs.
