need help clutch pressure plate size
Discussion in 'The Hokey Ass Message Board' started by enriq49fordf1, Sep 27, 2012.
  1. enriq49fordf1
    enriq49fordf1
    I have been putting together a flathead 8ba engine. It came with a flywheel no clutch parts. I picked up a 10" kit and it does not line up to the fly wheel. The bolt holes on my flywheel are 3" apart, the 10" kit is 3.125" apart. I have a 4 speed spur gear trans for it. Can any one help me out?:confused:
  2. Tequila Bob
    Tequila Bob
    from Michigan
    Do you have it figured out? I'd like to know also.
  3. V8 Bob
    V8 Bob
    Ford used several Long-style clutches. The info below should help ID what size clutch you need. :)
    http://www.centerforce.com/images/sites/centerforce/pdf/FLYWHEEL_NOTES_Web.pdf
  4. J Twitero
    J Twitero
    from Minnesota
    Stock 8ba in my 52 Mainline is a 9 1/2" clutch.
  5. Bruce Lancaster
    Bruce Lancaster
    Measure the part of flywheel that looks polished.
    Do you know what flywheel came from? There are a BUNCH of different clutches.
    See if polished area is around 9 1/2, 10, or 11...AND are the 6 holes in pairs with longer gaps between pairs or are they evenly spaced.
    That leads to...what transmission are you goin to attach the thig to?
  6. 40FordGuy
    40FordGuy
    Take the flywheel to a local clutch specialist, they'll get you what's needed. Easiest way, I found.
    4TTRUK
  7. enriq49fordf1
    enriq49fordf1
    Turned out to be a 9.5 inch flywheel. I ended up picking up a 10 inch flywheel at a local swap meet for $40. Then used the 10" clutch kit i had already ordered.
