My father-in-law has a farm, & occasionally needs to weld things like pipe for fences or farm implement stuff. He mentioned looking for a new helmet that would be large enough for him to wear his glasses with, & also one that has a larger view area than the old one he has. He went to Harbor Freight, saw one there, but didn't want to spend $70 on one. So, we decided to get him one for Father's Day, & I need some help picking out a decent one. Nothing too extravagant, just a good working one. Thanks! Steve
I use the Fibremetal Helmets, the old ones that have been around for ions... They are the standard helmet up here in the oil industry, tough as nails and last for for years when used for 10 hours a day. Good quailty. Excellent smooth action. Industry standard for a reason.... Probably 50 to 70$ in your area..
i use a cig helmet, its plastic but tough, i have this one for about 18 years and i have only replaced the head band once, mine has the small window that opens but you can get ones with large windows that open as well, being able to open the window lets you use it to grind or be able to see what your working on as well without raising your whole helmit every time. there about $30, in a non auto darkining helmit they would be #1 in production line welding.
can probably get these cheaper on fleabay is the only dad you will ever have http://www.welders-direct.com/merch...en=PROD&Store_Code=WD&Product_Code=04-0012-21
I have a Miller Big Window Elite and love it-nice, big viewing area, replaceable Lens Covers inside and out (to save the Auto darkening unit), very adjustable. I buy the Batteries for it at Radio Shack (it takes two), and it comes in many different Paint schemes. It is an expensive piece but I won't go back-
I have a Jackson with a big window (non-auto darkening) that I got for about $30 at the local AirGas store about 4-5 years ago. I frequently wear safety glasses under it with no problem, so I would assume most eyeglasses should fit under it. It's also very light weight. The only complaint I have is the tensioners that allow it to flip down have one "notch" that's too tight, but the next notch looser is too loose... but then I'm probably too picky.
I just got a Miller elite with a magnifying lens. I'm so in love with that thing I want to marry it! I got mine from Cyberweld . If I can make a suggestion, just buy the black one with no fancy 40 dollar graphics, and when you get it , give that 40 bucks to a local pinstriper to spruce it up.
I use the Harbor Freight auto-darkener (the small window version). I wear eyeglasses and haven't ever had problems with it.
I wear saftey glasses under my hood all the time with out a problem. I think its a Jackson. Has a pretty big lens (non-auto darkening) and was about $30.00
I have the Harbor Freight auto darken but I can't see anything with it if there's any sunlight coming from behind my head. So now I have a light weight black hooded jacket to put over the top of the helmet like the old fashioned photographers and no worries. I paid $50 on sale.
Those Harbor Freight ones work OK but drop them once and they're junk. I tried one of those sweet Miller ones once and man, them fucker's are awesome. Worth every penny, I wish I could afford one. I have a Speedglas and it is also an excellent unit. I would look on eBay for a good used Speedglas for between $50-$100. It'll probably be non-adjustable but they're excellent products, had mine for probably 5 years now and never had a problem.
