Need adapters for wire wheels
Discussion in 'The Hokey Ass Message Board' started by Joliet Jake, Jun 16, 2009.
  1. Joliet Jake
    Joliet Jake
    from Jax, FL
    I used the "search" feature and couldn't find quite what I was looking for. I have a set of 35 Ford wires I want to use and I'm running a stock 46 Ford front and a 68 Ford 9" rear. I was told someone on here makes/sells adapters or at least can point me in the right direction.
    thanks
  2. manyolcars
    manyolcars
    I googled when I bought mine
  3. Rob Paul
    Rob Paul
    PM Wheelkid here for what you need
  4. 18n57
    18n57
    Got mine from wheelkid...
  5. or you can shorten and re spline F100 nine inch axels
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    Andy from Kerrville TX here on the HAMB makes the early front adapter rings for wires to hydraulics.
  7. chaddilac
    chaddilac
    got mine from Wheelkid too!
    rallyamerica.com
  8. Wildfire
    Wildfire
    Eric at Riley Auto
  9. choppintops
    choppintops
    Speedway sells them cheap.
  10. Andy
    Andy
    I sell for $40 for 4.
  11. TERPU
    TERPU
    I you cut some 4" pipe into 3/16th's wide rings you can do it yourself. Lathe and cut off/parting tool.
    Tim
  12. choppintops
    choppintops
    Tim, there is your new entry for the next "tech week" :D
  13. swifty
    swifty
    Andy, can you post a pic of your spacers and why are they necessary?
    swifty
  14. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    The cheap ones will work for your front setup but you need my thicker ones for the rear.
    Jimmy
  15. Joliet Jake
    Joliet Jake
    from Jax, FL
    Thanks for the response guys, I'll get with wheelkid.
  16. Andy
    Andy
    Agreed! The spacer rings are for the 40-48 hubs. You need the thick ones for the later hubs.
    Here are my rings and a pic of a wire wheel showing the gap inside the bolt circle. Wheels will warp if tightened without the inside support.
  17. movingviolation
    movingviolation
    Wheelkid provided the ones for HAMBANDYS car.....they are awsome. If your going to get adaptors..........Wheelkid is the best option!
