A friend damaged his 305 block, in his record setting LSR car. He desperately needs to find a good block ASAP, so that he can run in May. So, I need a good used 305 Block that can be cleaned up at max 30 over. PM or email baharley4me@aol.com Thanks in advance!
yea i've got one. he can have it for free. its from an 86 firebird and i'm pretty sure its standard bore. come get it.
You might want to verify which type of 305 buddy is looking for. 86 should be the one-peice rear seal (which means different crank) as opposed to the earlier 85 and down 2-piece rear seal. Different crank means different flywheel mounting pattern on the crank, it might or might not matter in this case.
