Technical Need 1932 Ford Frame Dimensions To Locate Steering Box
Discussion in 'The Hokey Ass Message Board' started by missysdad1, Jul 26, 2016.
  1. missysdad1
    missysdad1
    Does anybody have the dimensions necessary to locate a 1953 - 56 Ford F100 steering box correctly on a reproduction 1932 Ford frame?
    Also, what would the steering/suspension geometry consequences of moving it forward an inch or two?
    Thanks!
  2. what steering box?
    missysdad1 likes this.
  3. KevKo
    KevKo
    from Motown
    Side steer or cross steer? Side steer placement is critical for bump steer. Cross steer you have some leeway.
  4. missysdad1
    missysdad1
    Sorry for being so vague. I'm looking to install a '53 - '56 F100 steering box in a reproduction frame. I've corrected my original post to be clearer. Thanks!
  5. Corn Fed
    Corn Fed
    Location also depends on the engine/trans/exhaust you are going to run. Your best bet is to mock it all up and see how much room you have. If you can, also have the dash/seat/steering wheel you are going to use mocked up so you can get an idea of the angle to set it at.
  6. The box is attached to the steering column. HRP
  7. missysdad1
    missysdad1
    Danny: Yes, but I plan to cut it for length and to splice in a splined end for an early banjo wheel.
    There are no holes in the frame yet so I can put the box pretty much anywhere, but I need the stock location as a place to start.
    Also, wasn't the F-100 box usually bolted in the same place where the stock box was taken out?
  8. F&J
    F&J
    You must do what he said. The last one I did was repro boxed, no holes. Early Cad 331 motor/stick trans, stock Cad manifolds, and he wanted to run hoodsides.
    I fussed with mockup forever to do what he wanted. Also, he ran a undropped 32 heavy beam and I had to get the drag link at the best angle possible. I am positive the F100 box in that car is not near the original location. Even the center hole was not at the same height as stock, as I was scratching for a 1/4" here, and there, to get the whole front half of the car right.
    Tiny motor and lakes headers would eliminate the fussy mock ups
  9. F&J
    F&J
    Early banjo needs keyway/taper. F100 is taper/splined
  10. image.jpeg Wescotts website should have frame dimensions/hole locations.
  11. missysdad1
    missysdad1
    I didn't find a diagram with dimensions at Wescotts and can't read the ones on the diagram you posted (old eyes). Can somebody just walk out into their shop and measure from the front spreader bar hole to the steering box hole on their OEM '32 frame? Sure would save a lot of eye strain. Thanks!
  12. DDDenny
    I can walk out to the shop and get you a closeup of the Wescott print.
  13. missysdad1
    missysdad1
    Perfect! Thanks very much!
  14. mickeyc
    mickeyc
    I have an original unmolested frame on hand. I can get the dimensions you mention if you still need them on Friday when I go to the shop.
  15. missysdad1
    missysdad1
    Yes, please. I understand that some of the printed diagrams are not correct. Thanks very much!
  16. bct
    bct
    I put mine in the stock location. Definitely would not work forward without serious mods to frame or box or both.
  17. robtlor
    robtlor
    from Lincoln NE
    Speedway catalog has a print with dimensions forbthe frame.
  18. big duece
    big duece
    from kansas
    Get your motor mocked up, and exhaust manifolds first. Mold the steering stuff around engine requirements.
  19. Flathead Dave
    Flathead Dave
    from So. Cal.
    Very important to do what CornFed said. Mock everything up for proper fit.
    Sent from my SM-G930T using The H.A.M.B. mobile app
