Need 1 3/4 wide lowering blocks?????
Discussion in 'The Hokey Ass Message Board' started by AA/Fuel34fordpu, May 28, 2011.
  1. AA/Fuel34fordpu
    AA/Fuel34fordpu
    I bought a set of lowering leafs and blocks from Jamco kinda hard to get on the phone but still I was very happy with what I bought. I installed the leafs then the blocks put the ubolt on wait a miunte. Why are the ubolts slanted I got my tape out I was sent 2 inch wide blocks and I need 1 3/4 wide. I called Jamco back 3 time left nice detailed messages with my name and contact info No call backs. Ok well then thats fine Ill spend my money else were.
    So now the big question is I need lowering blocks that are 1 3/4 wide by 2 inches high were can I buy these. Thanks
  2. lowkroozer
    lowkroozer
    can you trim the ones you have down to size ?
  3. lowkroozer
    lowkroozer
    Try chassis engineering
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    We hear what your say'n, but why are the U bolts slanted ? Whats the width of your springs and the center line of the bolt hole of the spring plate left to right ?
  5. AA/Fuel34fordpu
    AA/Fuel34fordpu
    no because they are not solid if they were I would....
  6. AA/Fuel34fordpu
    AA/Fuel34fordpu
    The blocks are for a 2 inch wide spring not a stock 1 3/4 wide spring that I just put on new. The spring plates are for 1 3/4 not 2 inch wide springs. Does this help you out?
  7. I have had this problem before with old mopars They have 1 3/4" springs ten years ago nobody made them. I made them from some heavy tubing.
  8. ironandsteele
    ironandsteele
    chevs of the 40's
  9. AA/Fuel34fordpu
    AA/Fuel34fordpu
    yep 49 Fleetline
  10. I think shooter54 meant that's where to get them :)
  11. CBennett1
    CBennett1
    from Sek
  12. 1971BB427
    1971BB427
    from Oregon
    You can't trim down the whole hollow block, but you can notch them for U bolt clearance. 1/8" at each point will get them straight, and not slanted.
  13. handyandy289
    handyandy289
    from Georgia
    X2 quick and easy
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes it do.
  15. AA/Fuel34fordpu
    AA/Fuel34fordpu
    The cat from Jamco pmed me Hope we can sort this out. Like I said before Im very happy with the other parts I got from him. Thanks for all your input guys....
  16. yblock292
    yblock292
    had to do this on my shoebox , worked fine
  17. I agree with chevs of the 40's. That's where I got mine solid blocks good kit. $60. No complaints.
  18. Ohio Rodder
    Ohio Rodder
