Narrow a Columbia 2-speed?
Discussion in 'The Hokey Ass Message Board' started by garyv, Jun 1, 2008.
  1. garyv
    garyv
    Can a Columbia 2-speed axel be narrowed?
    Thanks,
    gary
  2. duste01
    duste01
  3. garyv
    garyv
    Thanks. Guess I'm going on a (cross-country) parts roundup this Fall.
    gary
  4. duste01
    duste01
    the inner workings are towards the middle, so your still left with the axles and housings to deal with. There are two completes running on ebay and a complete set of outrageously priced controls.
  5. turdytoo
    turdytoo
    Depending on how much you are wanting to narrow it, you may be able to do it with stock parts. Do lots of research.
  6. jpbanjo
    jpbanjo
    from Tulsa, Ok.
    I've got one under my '32 (pic below) but it's an early ('35/'36?) unit with after marker spring hangers for a '32 spring which keeps the tires in under the fenders. If yours is the later '46-'48 wider unit, the right side Columbia outer housing bell will need to be shortened to match a shorter and earlier left side Ford bell. You also might want to replace the spring hanger forging on the Columbia bell to match the left side bell or use Pete and Jake spring hangers as I did. Every thing else from an earlier narrower rear end should work.
    If guys can convert Ford banjo setups to nine in. outer bearings and splined axles, this should be a no brainer.
  7. Narrowed and a lot more!
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    Check with Hot Rod Works in ID - those guys narrow banjos and re-machine the axles (or convert to modern axles).
  9. garyv
    garyv
    Thanks for the replies. The one I've found is a 1947. I wanted to make sure it could be narrowed to fit under a Model A before I invested in it.
    gary
