Good morning HAMBers! I have a quick question, since searching came up dry. I'm going to fab up a fuel line for my 61 GMC this weekend using that poly-coated brake line from NAPA. My question is: do you have to remove the poly-coat from the end that's going to get flared? If so, how would you remove it? I was thinking a quick pass on my wire wheel would do the trick. Also, would the poly coat allow it to slip in the flare tool? Thanks!
I usually clean the area where the flare is going to be. never had a problem with it slipping in the tool.just wire wheel about a 1/2 inch
Ditto. Cut and flared some a couple of days ago. Worked fine. Nobody asked, but I just can't get used to seeing a coating other than zinc on brake line tubing. Maybe that's just me. Bob
I'll just give it a quick touch on the wire wheel. My first thought was that the poly coat would have a "gasket" effect on the sealing surface, but over time it could suffer from creep effect and cause a leak. I'll feel better with steel-steel sealing surface contact. Thanks again guys!
never had one leak because of the coating on the flare. I have had them leak because some incompetent ass running the flaring tool. I work alone...............
Alright, looks like I'm going to just cut & flare without screwing with the coating. If it leaks, I'll kiss it on the wire wheel. Thanks again for the replies!
