Nailhead short water pump and pulleys
Discussion in 'The Hokey Ass Message Board' started by marq, Dec 13, 2005.
  1. marq
    marq
    Ok guys i need to know what the short nailhead water pumps were from.I need years models ect.Also i will need to get the right pulleys as well so i also need to know if anyone has a spare set going cheap cheap...................Marq
  2. marq
    marq
    bump
  3. Canuck
    Canuck
    Far from a expert on the Nailhead engines, but this may be of some help:
    Tall Blocks: 1957 -58 -- Short Pump
    1959-60 -- Long Pump
    1961-66 -- Short Pump
    From a article in WebRodder.Com
    I know my 66 425 has a short pump with 3 sheave pulleys. Would like to find a set of 2 sheave pulleys to fit, if not, I will cut the front sheave off to give fan belt clearance.
    Good luck with your search.
  4. marq
    marq
    thats bound to help..................thanks .........Marq
  5. suedesled
    suedesled
    This is correct. However you need to be sure not to mix up the pre-59 and post 61 pulleys. The diameter of the crank pulley is different and will interfere with the pump pulley. Get a complete set from the same motor. Especially since you are so far away.
  6. marq
    marq
    Marty start preparing my pulleys for me.I may be able to source a pump here .is the crank pulley the same?..............Marq
  7. TagMan
    TagMan
    There's more than just two lengths on Nailhead waterpumps. The one on my 401 is a little over 6" from the timing cover seat to the fan flange and it's for a non-A/C car ('59-'61). The A/C pump for the same years ('59-'61) are about an inch shorter. My parts book lists 13 different waterpump part numbers for V-8 cars between 1955 - 1964 (my book ends at '64).
  8. modelabrian
    modelabrian
    Marq-
    I have had good luck contacting Northwest Speed Equipment in Oregon. They have lots of Nailhead info and used parts. Their website in nwspeedequipment.com
  9. suedesled
    suedesled
    There are several different part numbers for the same pump and some of the like the 57 have no provision for the heater hose. ( it went striaght to the radiator). I keep several pumps on the shelf and there are really only 4 different pumps. this does not include the difference between cast iron and aluminum which will have a different part no. also. When you get your pump give me a measurement from the gasket surface to the fan flange and I will match it up to a core motor in the yard and pull all the pulleys from the same car. This will insure proper fit.
