Nailhead intake risers
Discussion in 'The Hokey Ass Message Board' started by texasred, Jan 5, 2011.
  1. texasred
    texasred
    from Houston
    Thinking of buying a set port matched intake risers for my 30 over 401 with a mild cam. can i expect more torque and horsepower using these
  2. donut29
    donut29
    from canton MI
    Nope dyno has proven they lose HP
  3. mj40's
    mj40's
    How much more torque do you need over stock? Those things have a bunch already.
  4. Port match the stock intake and exhaust manifolds, you will gain something.............donut is right, the risers do not work.
  5. mj40's
    mj40's
    I need to add a little height to mine to clear the Moon valley pan I will be using with a 66 spreadbore 4bbl intake. I was thinking of using a set of the intake flanges to get 3/8" rise. That should be enough. What do you think?
  6. telriv
    telriv
    from Conn.
    Cut the fins on the valley cover. It will be hidden under the manifold.
