Nailhead Buick Posi Identification
Discussion in 'The Hokey Ass Message Board' started by George G, Apr 18, 2011.
  1. George G
    George G
    Got a 65 wildcat and I'm thinking that I have a posi diff. Both wheels want to turn forward when you rotate one.
    No tag on the filler plug any more. Tell by a part # ? The 63 service manual says there is an X in a circle on the carrier flange.
    Any tips? Links?
  2. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    In the 64 manual, it is identified by an x with a circle around it located on the bottom side of the carrier housing flange.
    Hope this helps, either way look for an X somewhere!
  3. George G
    George G
    I also read that the Posi has a 3/4 inch pipe thread filler hole with a square head that you can put a wrench on.
    Non posi has a smaller 3/8 filler with a indented square that you would put a rachet into.
  4. telriv
    telriv
    from Conn.
    The way to tell is by what has been said is one way to determine if posi or not. The only exception is that the 3/4" square is the size of the wrench required to remove the fill plug. It is NOT a 3/4" pipe plug. It has it's own very fine threaded plug with a gasket. Very rare & hard to come by if one is needed. The 3/8" square that fits a 3/8" square ratchet into is an open rear.
  5. buford26
    buford26
    Tom, doesn't the oil fill plug trick only work on '63-'65 cars? According to the Buick Master Chassis Parts Book 1940-1967, all Buicks from '39-'62 used the same square plug as the '63-'65 posi cars. It is group number 5.400 part number 1390882.
  6. telriv
    telriv
    from Conn.
    I honestly couldn't tell you that fact as I don't really know. I do know that I have '61 & '62 LeSabre cars that don't have posi & don't have the 3/4" square. These are open drive rears. Both the '57 Specials I have I haven't really looked. Now I will have to crawl under these two & find out.
    Tom T.
  7. buford26
    buford26
    Here are some pictures of the ones I have, they are:
    1957 Special 3.07 Non-posi
    1957 Special 3.58 Non-posi
    1961 Electra 225 3.23 Posi
    1962 Wildcat 3.36 Non-posi
    1965 Riviera 3.42 Posi
