Technical Mystery Flathead Ford V8 Heads - Can Anybody I.D???
Discussion in 'Traditional Hot Rods' started by mart3406, Nov 2, 2010.
  1. mart3406
    mart3406
    from Canada
    Anybody I.D???
    I came across a vintage pic of a hot-rodded
    Flathead Ford V8 on the net with a pair of
    unusual, obviously aftermarket heads. Does
    anyone know what they are???
    Mart3406
  2. I would like to know also!
  3. Bruce Lancaster
    Bruce Lancaster
    Are those initials or letters cast right below the hose??
  4. mart3406
    mart3406
    from Canada
    I can't tell. I can't get any higher resolution
    from the pic. Also, the site where I found the
    pic - which doesn't actually I.D. the heads
    either, by the way - is a Brazilian auto blog
    (http://carrosantigos.wordpress.com/page/8/ )
    so the text is all in Portuguese.
    Mart3406
  5. Tore
    Tore
    I can see some air cooling ribs maby its from a generator off som sort ?
  6. Slick Willy
    Slick Willy
    I think those came up on a Thickstun (and other flathead heads) pic thread and nobody knew them there either!
  7. revkev6
    revkev6
    from ma
    don't forget, dual plug!
  8. 50Fraud
    50Fraud
    ...with only half of the plugs wired ???
  9. retro54
    retro54
    from PA
    For fuel economy... :)
    ..couldn't resist haha
  10. TexasHardcore
    TexasHardcore
    from Austin-ish
    I've seen either that picture before, or a picture of the same heads, can't remember where. They are pretty cool looking.
  11. I will state up front that I have no idea what the origins of these heads are but offer some suggestions to think about.
    Twins spark plugs are a common feature of aeronautical reciprocating piston engines. I believe the military may also demand such spec from time to time.
    Whilst Henry's aero flathead engine, as I understand them, didn't have finned heads or dual plugs. I query if someone else may have had a go at an aero flathead?
    The orientation of the fins is unusual and may suggest airflow other than conventional automotive use as depicted in the pic.
    This could be completely off track and they are simply hot rod items designed to deal with detonation problems.
    Looking at the front of the head it appears that the water jacket does not extend over the full width of the head. Further it appears that the lower side of the head where the water jacket bulge ends is solid and that part of the head is cooled and at the same time reinforced by the multiple fins.
    Bruce, any thoughts?
  12. mart3406
    mart3406
    from Canada
    Bump for the 'late night/early
    morning
    ' crew. Let's see if if we
    can solve this one! Anybody??
    Mart3406
  13. HeyyCharger
    HeyyCharger
    Attempt to make photo bigger...... Hopefully more luck at deciphering the letters.
    Very interesting......
    Poor attempt to say the least!:confused:
    Second try.....
    HC.
  14. crash11049
    crash11049
  15. klazurfer
    klazurfer
    Elco - Twin pluggs ? Not sure , but if you have a set .. Well then please share pix .....
    Klaz :)
  16. revkev6
    revkev6
    from ma
    saw an add in hemmings from a guy named don orosco for new elco twin plug heads....
    (Google Map - Yahoo! Map) Description:
    FLATHEAD Ford V8 speed equipment: want something rare and unusual? Elco twin-spark plug and Smith external water log cylinder heads and pre-WW II Ord heads & manifolds are available again after 50 years; also Nash twin-plug distributors and spare parts, as rare as it gets. Don Orosco, 831-649-0220, 831-626-2660, CA; [email protected]**42-YR**"
    btw, anyone else know what the cable that is strapped to the upper radiator hose goes too!
  17. HeyyCharger
    HeyyCharger
    I'd say ELCO too...
  18. revkev6
    revkev6
    from ma
    found a pic on the HAMB of an elco dual plug head. def. not the same. also heard there are a couple different styles. one being a bronze marine head.
  19. Dale Fairfax
    Dale Fairfax
    Has anybody considered the possibility that these were made in South America-Brazil or Agentina? There was some speed equip mfd down there.
  20. BJR
    BJR
    Did the Ford Tri-Motors have 2 plug heads?
  21. B Blue
    B Blue
    Ford Tri-Motors did not have Ford engines.
    Bill
  22. revkev6
    revkev6
    from ma
    correct, but yes, they did have twin plugs heads. lol
  23. LowFat48
    LowFat48
    could that be a Fenton logo on the water neck ?
  24. lockwoodkustoms
    lockwoodkustoms
    The marking on the water neck is not a typical Fenton or Eelco logo from what I can see. It appears to maybe a single letter logo .
  25. revkev6
    revkev6
    from ma
    looks like multiple letters to me. The marine company Elco uses a much rounder style lettering. Eelco uses a blocky all caps logo that tapers I believe.
    From my eyes, I'm seeing an "E" then an I,J or L then what could be a C, O A or D.
  26. propwash
    propwash
    from Las Vegas
    I passed the pics around the "old dudes" (just as if I was NOT one) out at my airport the other night. No hits, but the opinions as to the application echoed the sagacious suggestions by 'freduece' in an earlier posting. Military did require redundant ignition systems for other vehicles besides aircraft. This is very intriguing - if anyone can ask Orosco directly if he's ever seen/touched these heads, his response could only enhance our quest for info.
    dj
  27. lockwoodkustoms
    lockwoodkustoms
    If you take the pictures provided and invert the colors you will see why I think this is more of a one letter or possibly two letter logo than the typical full name logos that where primarily used back then.
  28. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    the Ford Tri-Motor airplane had 3 radial engines
  29. kaboom
    kaboom
    from STL, Mo
    It looks like ETO or ETC to me.
  30. Slick Willy
    Slick Willy
    Im going out on a limb here....
    "possibly made in brazil..." was said earlier.
    I did some redoing of the pic and it appears (to me anyway) to say "FRANCE" under the center stud, in an arc'd pattern...
    putting two and two together, could this be an early version of the emisul motor by simca?? the way the heads are bulged looks like a way to make a "hemi" shape.
    all this and the time frame of the the late 30s block...it could be!
