I bought this a while back hoping to maybe make use of it. It would work well mounted in the toe board. It has seals on the shafts, and pretty much water tight from the outside. I believe it is magnesium, but don't know for sure. Anyone have a clue what is from originally?
Neat part, not off anything I recognize...used to have a master cylinder mounted on it, apparently? What's that number and casting symbol?
New to me but it looks extremely well made. Looking at the mounting attachment area it appears to have originally been mounted on the firewall or it could be something from the UK. HRP
The only # that is on it is 1355-66024. I thought maybe one of those amphi-cars when I first cleaned it.
Alfa Romeo Giulietta http://www.alfabb.com/bb/forums/alfa-romeo-parts-sale-wanted/487849-giulietta-giulia-101-parts.html
well, once the numbers are posted, it's just a quick google away! the trick is to put quotes around the whole number sequence, then you get only one result, which is the right one. And a lot of luck helps, too
