Features My Thunderbird is out of storage after 5 years.
Discussion in 'The Hokey Ass Message Board' started by Edsel58a, Aug 24, 2013.
  1. Edsel58a
    Edsel58a
    One of my many projects. Bought this cheap about 5 years ago and it has been parked since. Not sure which way I want to go with it, I do like the magnums tho, but kinda leaning towards wide steel wheels and raised white letter tires for the stock car look.
    I want this to be a simple, but unique car. Runs ad drives A1 and I am gonna drive as is for awhile, At least til the snow comes.
    And the patina took years to achieve.
    Any suggestions?
  2. T_Bird Guy
    T_Bird Guy
    Lowered with steel wheels is the way I went with mine.
  3. Edsel58a
    Edsel58a
    I like that look, mines is pretty low as is. Hmmmmm.....
  4. Lowered with Astros on mine
  5. +1 to chainsaw's lowered and Astros car.
    TBirds have always, at least to me, been so understated and subtle that trying to make them more of a hot rod never looks "right". If it were mine, get it a little lower, consider simple painted steelies and pinner whitewalls, then look at color combos you really like.
    A word about wheel changes though: a buddy of mine had a '62, and he couldn't find recently-made wheels that allowed him to still keep the skirts. While the removal of the skirts ended up visually lightening the rear of the car, it did look less "kustom".
  6. 1967gt
    1967gt
    from ohio
    Anybody needs any parts . I have a 63 parts car..
  7. Honestly if I were you, I'd keep the wheels stock, and get a nice pair of tires. But it's your car, put whatever you want on it and make it unique to you. Maybe touch up the paint in rough areas or not, and put a clear coat or something over it to maintain that patina look.
    These are beautiful cars, someone nearby has an all white one with the swing away steering wheel (not sure if that was an option or standard?) Very sleek and nice.
  8. indyjps
    indyjps
    Ditch the skirts, rearch the rear whelwells to match the front without as much height, then absolutely fill the wheelwells with body color steelies and fat rubber, spider caps if you prefer
  9. Toast
    Toast
    from Jenks, OK
    Here is the way mine went, love those Birds, looks like you have a good foundation.
  10. herbet99
    herbet99
    from Central NJ
    Steelies with wide whites for me
    And reduce the thickness of the b pillar... Maybe even bubble top.
    That's how I'll do mine
  11. 46stude
    46stude
    Nice T-Bird. I'm thinking about slotted aluminum mags for my '62, maybe run thin white walls.
    General question for those reading this thread:
    Does the HAMB have a '61-'63 Bullet Bird picture thread? I have searched but come up empty.
  12. Edsel58a
    Edsel58a
    All worthwhile suggestions. The body will not receive any extensive mods. Some trim trim removal is about it. Wheels and tires can always be swapped, so for now I am just installing magnums on the rear also. Skirts coming off, but may go back on at a later time.
    Eventually it will be painted. interior is white, so color is wide open.
    46Stude, Maybe I'll start a Bullet Bird thread.
  13. Edsel58a
    Edsel58a
    Temporarily updated the look. Upon removing the old tires I found 3 bias ply and 1 radial.
    Also found the car is missing a shock. Generator light is staying on, I may switch to an alternator. I have one with brackets and wiring from a 67 390. I think there is only one connection to make. Am I correct? I am wiring illiterate.
  14. 58custom
    58custom
    67 alt is externally regulated. Also, generator blocks are a little different where the generator bolts to block and the water pump on early FE blocks like mine so that may be an issue as well. If it were me, I would adapt a G3 130 amp internally regulated alt to it using the available conversion braketry and that way you can remove the gen regulator. I've used that alt on a couple of cars and it works great. Just have to add a 560 ohm 2 watt resistor in parallel with your indicator light (or it won't charge).
  15. Edsel58a
    Edsel58a
    58 Custom, will this allow my generator light to still function? I actually did think about the G3, but had the other parts at my disposal.
  16. 56BlueBird
    56BlueBird
    from USA
    Since you asked for thoughts I'd personally go with the fender skirts and whatever wheel/tire combination. Just don't go so low you can't clear a speed bump.
  17. toml24
    toml24
    You have a great looking T-Bird. The best paint job I've ever seen for a T-bird of this style was raced by Clem Proctor at Riverside and Ontario. That was a fast car!
  18. Heo2
    Heo2
    this
  19. gecko54
    gecko54
    from Sumner, WA
    ^^^^^that's badass......and this coming from someone who went the custom route.
