Customs My shoebox chop
Discussion in 'The Hokey Ass Message Board' started by Stefan T, Oct 21, 2009.
  1. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Good to see that your project is going forward. Looking good.
    VR&C
  2. oldman2
    oldman2
    Looks great, keep it up...Jim
  3. BrerHair
    BrerHair
    Nice work Stefan, as always.
    Interesting that you did not run front brake lines through the frame, but ran them over the top of the frame. I have always wondered why all instructions seem to say "run through frame". Must be some reason, but I do not know why your set-up will not work.
  4. Stefan T
    Stefan T
    from Sweden
    Thanks for the coments
    We want see if it works with the brake lines or not
    but one thing that my car is diffrent is hat i don't use the original steering knockel
    but over to the update
    i have not done a update for a whail but have done som work
    the fram have no machinery so time for that
    so i take the ford flathead and use that
    i had to install the chevy cluch on the flywheel
    the BMW tranny (Getrag 260) is on the flathead
    and i don't say annything of all the tubble there it was with everything
    before the motor package was in the frame. ( there was lot of them)
    The blown flathed installed in the frame
    The new engine monts had to small holes so they need to be drilled up
    Time for make the the euqal lengt headers
    I have done the pipes earlier see earlier in the thread
    We tack weld them in the car
    A pic of the passenger side
    The driver side
    Both sides cut to same length
    From a diffrent angle
    My sister son Andreas are welding the pipes together in the colector area befor wr take
    them out from the fram
    Out and ready to ready weld them
    And this was all from me today acc. the update
    /Stefan
    model.A.keith likes this.
  5. oldman2
    oldman2
    Stefan, nice update, engine looks great setting in frame. Those headers are over the top, super nice looking...Jim
  6. Stefan T
    Stefan T
    from Sweden
    Thanks for the comment
    I have worked with my shoebox
    and the parts i have worked with was the headers to the flathead
    I have mad pyramids of 42 mm pipes and weld them inside the collector
    (the focus were on the griders insted of the collector)
    the outside of the colector is now welded on the headers
    an look in the collector
    as you see ther's a pyramid in the middel of the collector
    the other sides collector
    it was necesarry to make a new oil pie to the oil filter
    The new oil pipe and i did it on first try
    the headers back in the frame
    Maybe shall i do the exhaust system somthing like this with x-pipe
    /Stefan
  7. oldman2
    oldman2
    Stefan, everything looks great, I think the X pipe would be great...Jim
  8. farmer12
    farmer12
    Great work as usual Stefan, looking good!
  9. Stefan T
    Stefan T
    from Sweden
    Thanks for the comments
    update:
    I have worked with the exhaust system.
    Here have laid the pipes that should be the x-pipes on wood pices
    and made some sheet metal parts to fill out with when cut holes in the pipes
    The pipes are here tack welded
    The x-pipe in place in the frame and rhe mufflers are in place too
    The pipes are hanged with 30mm M8 rubber dampers, the x-pipe have 2 hanged in the frame
    and the 2 to the mufflers are hanged in the old emerdgency brake cable holders
    Next everfing shall down and thats not are welded shall be welded and the x-pipe and the
    headers shall be pickeled
    /Stefan
    daddio211 likes this.
  10. oldman2
    oldman2
    Looks great...Jim
  11. Stefan T
    Stefan T
    from Sweden
    Update but not from today we in sweden are not celbrating thanks giving
    The headers and x-pipe have been pickeled
    the headers are on place with gaskets and hope fully not need to be removed before start
    of the engine.
    The x-pipe are in place with the mufflers the rear part of the exhuast stystem shall i do
    when the body are on place so it fitts good
    The parts for the clutch release transmision need some changes to fit with the headers
    I cut the old part betvine the shaft throu the frame and the gearbox in 2 pieces and
    weld in a 1 1/2" x 0.065" (38.1mm x 1.65mm(USOD)) pipe in the top of it insted of
    the bracket in the bottom that hit the headers
    /Stefan
  12. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Looking really good Stefan T.
    VR&C.
  13. Buddy Palumbo
    Buddy Palumbo
    Wow - I didn't see those headers coming ! Great work , as usual .
  14. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    I've been following you since day one Stefan, and you do not disappoint..
    The headers are very cool, cant wait for the video ....
  15. oldman2
    oldman2
    Looks great with the exhaust together...Jim
  16. Stefan T
    Stefan T
    from Sweden
    Thanks for all coments
    I shall post a video with the sound and the car when i have started it up
    but it would take some time before that in best case to the spring
    now over to a little up date
    The clutch pedal and the meckano to the clutch is in place
    I was afraid it should be to havey to realase the clutch but it were more easy than i suspect
    Both the brake pedal and the clutch pedal in place
    I think that i need at last lower them before i place body on the frame
    /Stefan
  17. Stefan T
    Stefan T
    from Sweden
    Update
    I have made a pressure pipe to the power stearing
    it shall to have a new hose insted of the old i have tested with the flang shall be
    weled and the other end shall be new one to
    I have fix the emedegecy brake cable it is made of the old one and some new made
    hooks the cable locks are made of 10x1 mm pipe
    Here is the wheel to the speedometer
    And here is the sensor in place with it's new bracket
    /Stefan
  18. Stefan T
    Stefan T
    from Sweden
    Little update!!!!!
    The old Volvo 140 tank need get ridd of the old under coating
    After some work looks it good
    I have started to scrape the coating with hot air gun and a scrape
    After that cleaned i it with solvents
    /Stefan
  19. Finnrodder
    Finnrodder
    from Finland
    Nice progress,Stefan.
    Those headers looks great!
  20. Stefan T
    Stefan T
    from Sweden
    Thanks
    more update
    the bottom of the body have get some coating (biltema tröskelskyddsmassa 362414)
    The new pressure line to the power steering is ready
    and in place
    and now is that's near for the big lift
    /Stefan
  21. Stefan T
    Stefan T
    from Sweden
    The weather was nice for to be in December
    and the frame is out on is own wheel for the fist time
    Now have it change direction with engine in south insted of north
    With enought with peopel it is easy to take down the body
    Me and my sister lool on the body now down on the floor more or less
    Now lift we the body and move it.
    down
    down
    down
    down
    down
    Out. On the pic you can see me and my sisterson
    An now we land the body on the frame
    from a outher view
    Her's body in place on the frame
    seen from the front
    Seen from south east
    And back in doors in the garage work shop in the big barn
    /Stefan
  22. engine138
    engine138
    from Commack NY
    Before and after just killer
  23. oldman2
    oldman2
    Nice update, body on the frame is looking great, nice job...Jim
  24. Stefan T
    Stefan T
    from Sweden
    Thanks
    It have happen a lot with the shoebox since i bought it
    and maybe a supriceing result
    and now shall go to the garage to srcew body to the frame
    /Stefan
  25. Thanks for the update. Can't wait to hear that engine!
  26. BrerHair
    BrerHair
    Outstanding! Looking great!
    "Pickeled"? They look painted, maybe powder-coated, but pickeled? They look great.
  27. Stefan T
    Stefan T
    from Sweden
    Thanks all for your comnents
    The headers are in AISI 316L/1.4404 (stainless steel acid proff)
    Pickeled is when stainless steel or something are put in a acid bath so all coloring after welding is
    removed and the weld can be full stainless and passivated
    Little update
    I have screw the body to the frame
    I begin with to long screws so i can lift in the body little so all screws can be fitted
    And then all screw was fitted i switch them to right length
    I have use M10 insted of 3/8 UNF so all the threads in the fram is rethreded with M10
    M10 is mutch cheaper (i can get them for free and even with out that get them for free)
    and mutch easier to get in all cases
    Her's some parts to the ventilation in the engine bay that need some love!
    Have someone a tip of some fan motor + wheel that fit without big modifications
    from newer car that are common on the junk yard in sweden (EU/Japan cars 10 to 25 years old)
    /Stefan
  28. oldman2
    oldman2
    Yes, they can use some TLC, which you are good at...Jim
  29. BrerHair
    BrerHair
    Thanks for the education, Stefan. You are a bona fide metal man!
  30. Buddy Palumbo
    Buddy Palumbo
    I have a fan motor from a mid-70's Ford Econoline on my shoebox . It was cheap to buy new , bolted right up , was 12volt & spun the right direction . It has the right sized shaft , so the stock "squirrell cage" fan fits right onto it .
