Thanks for the coment The timing gear cover is fixed for use of a Chevy distubrator but it have still some green color so i have to fix it I polish it and assemble it to the flathead and the oil pump is mounted to one more pic on the oil pump with the oil pressure connection out in the bottom to the filter The pan is now on place too /Stefan
Man, that's looking sweet, Stefan. I really like your solutions to the challenges you have faced. Really creative. Kevin
I belve not to fire it up in the stand In that case need the radiator and thats so easy to have in the stand /Stefan
I have build little more on the flathead I shall have studs to the heads so now are they on place the blower mainfold must be assembe to the motor before the heads I have made a plug from a M12 bolt to the fuel pump push rod hole My sisters son Andreas help me with blower mainfold. the manifold is one place the navarro heads is on the flathead Water pumps is bolted to the engine The heads shall be torqued. I seen that the alu head shall have diffrent torquy settings than the cast heads Is there anny how knows how mutch is the right to my navarro heads? /Stefan
Looks great Stefan. I'm sure the Herman brothers will help you out: http://flatheads-forever.com/contact-us-specialmenu-127.html
Torque spec on aluminum heads is 40 lbs, Stefan.......don't overdo it......and there is an order to tightening them down......you start in the center and work your way out... There's diagrams in a lot of books on the order of tightening the head nuts... CB
I would trust anything Max or his brother says. They definitely know thier stuff. Max is crazy like you!
Thanks for all that like my shoebox build and flathead build too Little more parts on the blown ford flathead The blower is on for test The blower is a GMC 3-71 I must line up all the pullys so it will some shims and the crankshaft wheel shall i make little shorter /Stefan
thanks for the comment i have worked a loot with my Oldsmobile so it have not been so mutch shoebox work The engine is in the car but the new th 2004r are left to assemble in the olds but i have line up the pullys /Stefan
Thank for the coment I have put in a extra wheel to get more angel around the crank pully So it will be better posibitys to drive the blower on the 8ba flathead a last pic before i disassemble some parts from the motor before painting it. /Stefan
The blower is approx 8% overdrive if i rember right The picture make the diffrece wrong so the blower pully is smaller than the crank pully
Thanks for all coments I have worked little on my flathead I have ground paint it so next thing will to paint it /Stefan
Your engine looks great, been enjoying this thread a lot, thanks. Is that a single serpentine belt runing everything?
