I pretty much have the car blocked minus the hood, thanks to my boy Lincoln, so stood back and I kept staring at it trying to figure my next step, and the damn smooth inner rear fender wells kept jumping out at me..After a couple days I couldn't take it anymore and made some beads that matched the original stamping and glued them in place..I can't get over the gluing thing...
Looking good Matt, are yo going to fit a standard tank and redo those rails, or leave it bobbed? I've got some photos for you..... cheers, Drewfus
I'm going to keep it bobbed Andrew, I like that look. Reminds me of a Hotwheel that my pop modified for me when I was a kid..
Been a few weeks since I have been able to play with the coupe. I had me a baby girl a few weeks ago and between that, no sleep, my boy starting kindergarten and fabbing up a bunch of rocker panels for the Mercs, my play time on the car is non exsistant!! In the mean time I was able to chase down some needed parts. I managed to round up a pretty descent hood and sides from a fello Hamber, and found a very nice grille, after being outbid on one I was watching on ebay..Got them sand blasted and straigtened out and set on the car for a looksy..Looks pretty good to me! Some epoxy primer coming soon!
I just so happen to have a few 94's laying around and after a few inquires, a buddy said he had an Edelbrock 6x2 for an Olds engine. The ports between the engines are damn near the same as the Caddy, but the degree on the mating surface and the bolt holes are off. So after a little welding and a surfacing I'm good to go! I don't plan to run all the carbs, just planning on the centers. Anybody reccomend a linkage set up they like? I really don't feel like building one.. Now I just need to repray the enging color and get those carbs all spiffied up!
Imes-tay oo-tay !! Nice way to do a winter safe driving hot rod. Nothing wrong with that. Affordable and fun, with a man that obviously knows what steel means. Good enough for me. Glue away brother !! Vroom vrooom ! Edit....just saw you're already a Cali' guy....funny.....yeah winter safe driving.
My ass has been lagging on some updated photos..Picked up some new inner fender panels for it and made some new radiator mounts . I had to modify the panels since the frame is pinched. Made the little window fins on the doors, this body didn't have them. I also ended up mounting some 41-8 tail lights instead of the 37's since I dropped and broke a lens. .
Next on the agenda was to address the floor boards which were hacked up pretty good, and it needed a trans cover made also. So I popped the engine back in and started at it.
Once I got that stuff all shaped I had to mount the column. It came with a tilt and and another fixed column, so the tilt got yanked out. It had all the joints and shafts to convert it back, just had to lengthen one shaft so the column was set to my liking. On the lower column mount I was trying to come up with something cheap and laying around the shop and I happen to spot an aluminum AC vent, which just happen to be the same size OD as the column..COOL! So the inner baffle was removed and it is now a custom column mount. Once that was situated I made an upper column drop.
beautiful…love the 46-48 tail light treatment….. always look the proper part on model 40s.Love the build.
Love this build. The ride height is perfect. Wheel and tire size? Posted using the Full Custom H.A.M.B. App!
Nice project. Last 34 hiboy we did, we made custom hood sides and blister panels, was easier than cutting up stock ones. We also laid the grill back a little more than stock. The changes you made to the wheel wells and doors turned a 33 into a 34. That is a good looking body and you are building it into a cool hotrod!
I owned a '34 Tudor for years, but didn't know there was a difference in wheelwells between '33 and '34's. Please enlighten me..
Yes sir, welded studs and smothered it with some epoxy and bolted them into the recess I stepped in the panel.
Lovin' this thread! The '33-'34 Coupe's my all time favorite Ford. Any updates? Little 5-year-old Lincoln out in the shop workin' on dad's car...you're bringin' him up just right! Congrats on your new little girl, what did you name her? Victoria? Shelby? ...?
Gary, '33s have a smooth wheel well, no " crows foot". I put '34 wheel wells in my '33 coupe, just coz I like them! Cheers, Stewart
