Projects My radical little T coupe.
Discussion in 'Traditional Hot Rods' started by Austin kays, Oct 13, 2021.
  1. Tim
    Tim
    from KCMO
  2. The full width minitruck mirror prob helps driving A LOT
    Austin kays, Stogy and Tim like this.
  3. 6sally6
    6sally6
    Nice write up.....
    I really love the "Kiss-my-ass" attitude the chopped T shows!
    Please tell us your gonna get some front brakes on that puppy before the blower and other stuff.
    Definitely a "bare bones" look.....will you have a problem getting tags for it?!
    One quick question.......why did you X the pipes between the front and the radiator? I think.....it woulda been a cleaner job if the pipes had each gone straight back! (IF you ever have air bubble issues in the long cooling pipes just park it with the rear higher than the front...remove radiator cap....bring engine up to temp....It should 'burp' all the air out no prob.)
    Cool ride
    6sally6
    PS.......after seeing all those cars at the Cruis'in the Coast please tell me you have that Shivel-lay motor cammed 'out-of-it's-mind!?! A hot rod needs to sound like a hot rod!!!:cool:
    mad mikey, Stogy and Tim like this.
  4. Tim
    Tim
    from KCMO
    @6sally6 scroll back and you’ll see the Buick drums thst will go up front ;) current motor has a cam in it but is on its way out. Putting a new one together this winter, grabbing a block and getting started this weekend.
    it will be as nasty as he can afford it to be. And it’s a sbc so pretty nasty I’d guess lol
    mad mikey and Stogy like this.
  5. BigJoeArt
    BigJoeArt
    in missouri we can get historic plates without inspections. so it will be relatively easy to plate.
    and for your other point, it would have been cleaner, but then it would have been pumping hot water in the bottom of the radiator, which didn't seem like a good idea. so the crossed pipes is to correct flow, so just like your front mounted radiator, the hot water goes in the top and cool-er water comes out the bottom.
    and we learned all about correctly filling the rad... this was waiting for the thermostat to open to fill the rest of the way after swapping heads. 20210907_194653_HDR.jpg 20210907_194853.jpg
  6. Stogy
    Stogy
    I thought there was a Weesner influence in there...
    dana barlow likes this.
  7. Nailhead A-V8
    Nailhead A-V8
    sweet coupe! that smile says it all....@dana barlow has been hot rodding for over 65 years guys like him are invaluable in terms of history and experience...not sure there was call to get so defensive over a guy offering his insight...now I'm afraid to ask my question about why the engine is so high up? and if there are plans to lower it for vision issues that might occur with the blower
    Outback and WalkerMD like this.
  8. Tim
    Tim
    from KCMO
    @Nailhead A-V8 I think the motor looks extra tall because the body is channeled. That car is very low, Im sure he figured if the motor was lower in the chassis the oil pan would become sacrificial.
    @Austin kays wanna throw a tape on it and see how far from the bottom of the pan to the ground?
    also I’m sure how it looks came into play, it looks pretty dead on to how @BigJoeArt always draws hotrods. It was kind of a “hey I bet I’ve got enough in the garage to build this drawing” kinda build I think
  9. This is an idea for radiator cooling. A member here(?) called Littleman did this one up. 06.jpg
    SICK AL, mad mikey, Dean Lowe and 7 others like this.
  10. See above ;)
  11. Nailhead A-V8
    Nailhead A-V8
    Yeah...like that crazy purple vicky that gets all 4 wheels off the ground!
  12. Tim
    Tim
    from KCMO
    The purple people eater is a lot taller. 514BA028-B406-4744-8875-93C37BBF4CD5.jpeg think more cherry pie ;) 11606BAE-0869-408C-9C86-8257C313D1CE.jpeg because of overturning else going on it’s easy to miss how channeled this thing is. It’s pretty common for a carb top to be even with a T cowl too with out a channel
  13. Tim
    Tim
    from KCMO
    @Paul current project for visual reference of a non channeled T body/ engine relation.
    it’s easy to forget how tiny and low this coupe is because of how aggressive looking it is. There’s not really anywhere else for that engine to land.
    either way, yeah, it’s pretty radical C1BFDED2-2DD4-4C81-AE4A-D30AEED93EBF.jpeg 2420DDB4-5196-4029-BADA-C2C64873F31A.jpeg
  14. Tim
    Tim
    from KCMO
    Mock up bullshitting session with a blower and the top of a T grill shell ED098EC9-BA1D-4942-9C67-4791E638550A.jpeg
    brEad, mad mikey, Vic Walter and 13 others like this.
  15. AHotRod
    AHotRod
    Cool Hot Rod , I love outside-the-box Hot Rods.
    mad mikey, Just Gary, Tim and 2 others like this.
  16. Tim
    Tim
    from KCMO
    Yeah should be pretty neat, He’s been driving the wheels off it
  17. Tim
    Tim
    from KCMO
    Little radical T inspiration F2D7FA93-0ED8-4671-8CF2-A0746D2B9A7F.jpeg CE5526CD-130A-4679-BD39-7C8551D3E230.jpeg
  18. Austin kays
    Austin kays
    Well ordered the street supercharging book but was the revised edition so ordered the second one with detailed re build and conversation details and while I was doing that my 671 multiplied!
  19. Austin kays
    Austin kays
    Outback, brEad, mad mikey and 10 others like this.
  20. Tim
    Tim
    from KCMO
    Musta fed them after midnight?
    brEad, mad mikey, dana barlow and 3 others like this.
  21. Austin kays
    Austin kays
    81F0E512-026D-4EAA-88B2-9AC330A00A2E.jpeg D0F51709-CAF6-4083-BEE9-37EEB6922FE6.jpeg
  22. Austin kays
    Austin kays
    Picked up a 32 shell and insert and decided it was gonna be the one on the T cut it down and fit it around today.
  23. Tim
    Tim
    from KCMO
    Absolutely love it! This is shaping up awesome :)
  24. Nailhead A-V8
    Nailhead A-V8
    brEad, mad mikey, Tman and 4 others like this.
  25. Tim
    Tim
    from KCMO
    Thinking we need to start a go fund me so he can put a half dozen of @stromberg-97 carbs on top Of that blower!
    Sancho likes this.
  26. Roger Loupias
    Roger Loupias
    This thing's a kick in the ass and you know it. Any chance you get, hug the lane to environmentalist bike paths. Green peace.......................
    Austin kays likes this.
  27. Tim
    Tim
    from KCMO
    It’s so fun seeing it tear down dirt roads kicking up a mile of dirt clouds
  28. Bugguts
    Bugguts
    Looks way more finished with the grille shell! Good choice!
  29. sunbeam
    sunbeam
    Have you run the car enough to see if it stays cool? I am in the process of a similar build using a early Dodge 241 hemi but using a electric water pump. Fingers crossed that it stays cool
  30. Tim
    Tim
    from KCMO
    600 miles and counting and hasn’t puked once
    mad mikey, Just Gary and Stogy like this.
