Hi there. After years of chase, money saving and disappointments, I finally managed to buy a roadworthy, road inspected 1956 Ford Customline. Man Im so thrilled Im hardly able to sleep! Heres a short sequence of the trip: Taking my old 1968 Opel to take part on the deal, getting acquainted with Cruella, the 270kms journey back home (sweating due to a carb leak right to the top of the manifolds), and the car at home. Sorry for the crappy cell phone pics. Now I need some help: besides other problems, my throttle pedal keeps leaning to the left, because the part that holds the throttle shaft through the firewall is missing. Can anyone show me a picture of this particular throttle shaft-through-firewall setting, or maybe a part of this Ford manual / factory hand book so I can figure out what is missing? Thanks a lot.
Congratulations on the Customline! I have become somewhat partial to 56 Fords since I got my Fairlane. I am betting there aren't many of those in Portugal.
Thanks for the input guys. I'm very happy. Here, as you might imagine it is really hard to a) find a customline b) find a road-worthy, road-inspected customline and finally c) a road-worthy, road-inspected customline that can be bought for a reasonable price and that doesnt belong to some rich garage princess maniac that doesnt even drives his cars. Oh... and yeah I love the rust on her grille. Could someone please post a shot of / explain the throttle pedal through firewall assembly. I'm missing something here, I mean, yes I can build some sort of axle / tube bracket that would work, but I guess Ford already did that. Thanks and keep it up.
I will try to remember to take a couple pics of mine although it could be different since it is a y-block car.
I am not sure but I think Dennis Carpenter in Charlotte NC may have the parts you need...just google... WWW.DENNIS-CARPENTER.COM He probably has a catalog on line that shows you what you need...
I can't go and look. I'm not near it now but from memory I'm pretty sure the pedal is not serviceable. Find a gas pedal assembly from another 56. They are all the same and should simply bolt right into the firewall. It sounds to me like your pedal is broken. Replace it and be done with it. My gas pedal stayed in place while the engine was out. There are plenty of 56 Ford guys that part out cars and this is not a hot item. It should be very cheap. This was 6 cyl car and the gas pedal seen here hooked up to trips was the easiest part of the build.
It doesn't go through anything but the floor,you need to replace the worn out pedal because the rubber is shot,the link that passes through the floor has a mushroom shaped head on it and in time they wobble out the rubber and the pedal gets sloppy:http://www.ebay.com/itm/1955-1956-F...Parts_Accessories&hash=item258c8f1b85&vxp=mtr You can see a good view of the pedals backside here too.
You should really order this too: http://www.ebay.com/itm/1949-59-For...anuals_Literature&hash=item564bdf821d&vxp=mtr This contains an Illustrated section that shows every component of your car and where it fits so you can print that out when you go out to the garage to work on it also the Parts section can be used to find parts on the web by doing a search of the Ford part numbers so you can find them and get the best deal,that CD will be the best "bang for the buck" you will spend on your Ford. CLICK on the picture below to enlarge.
Hi JeffB52 I think he is talking about the throttle shaft that runs through the firewall .. There is a bracket with a plastic bush attached to the fire wall above the pedal ...the pedal rests on the shaft where it pass's through a hard rubber grommet in the firewall...think this is missing or is broken..
