Projects My new 1928 Chrysler 5w coupe
Discussion in 'Traditional Hot Rods' started by tallhtrddr, Nov 19, 2013.
  1. tallhtrddr
    tallhtrddr
    Thought I would share with you guys my new coupe. All original ride, roll down rear window and front windshield rolls up. Everything there. Going to do a fender less traditional with 331 hemi and 4 speed. What do you think? ImageUploadedByH.A.M.B.1384908044.751288.jpg ImageUploadedByH.A.M.B.1384908062.866352.jpg ImageUploadedByH.A.M.B.1384908084.571417.jpg ImageUploadedByH.A.M.B.1384908128.718132.jpg ImageUploadedByH.A.M.B.1384908154.464087.jpg
  2. ROADSTER1927
    ROADSTER1927
    Very Cool, what are your plans? Gary
  3. Jimmy2car
    Jimmy2car
    from No. Cal
    That car deserves it's fenders
  4. scrap metal 48
    scrap metal 48
    Great looking car and sounds like a good plan...
  5. ss34coupe
    ss34coupe
    good luck with the project, and good for you for building something different. It doesn't always have to be a Ford!
  6. tallhtrddr
    tallhtrddr
    Thanks guys like I said before 331 hemi. 4speed. No fenders. Lake headers 3 inch chop. Not sure about suspension. May go with a ford may not
  7. tallhtrddr
    tallhtrddr
    I'm also looking for a 331 hemi. I had the long bell block and want to build a 54 or newer block. Putting in a Mopar 4 speed Also planning on using 18 inch divico wheels but that is all I have planned now. Will be building new frame after thanksgiving
  8. ROADSTER1927
    ROADSTER1927
    That Chrysler frame is pretty beefy, why not use it? Gary
  9. nitrohemi
    nitrohemi
    i have a s6 Chrysler no need for a new frame if its not rotted those frames are bigger and stronger then whats on my 20 year old dodge truck I boxed mine back to the first crossmember and welded a lot of the cross members in
  10. tallhtrddr
    tallhtrddr
    Frame is spoken for so I have no choice in that matter. As far as front suspension do a ford buggy spring or keep it like is with factory type?
  11. nitrohemi
    nitrohemi
    I kept the original front springs. I like the different non ford spring setup. I am looking for a set of original rear leaf springs
  12. Cool car! I have a '28 Chrysler instrument panel I am using in my current Model A project.
    My dad bought a three year old '28 Chrysler after having a new Model A for a couple years. He kept buying Chrysler Corp products the rest of his life after that first chrysler.
    I would probably use a deuce frame if your original frame is spoken for. …and Ford transverse spring up front. Good luck with the project.
  13. ml_engr
    ml_engr
    Cool project. Will be great to see something different come together.
  14. tallhtrddr
    tallhtrddr
    Thanks again guys ill keep you posted as I get it done
  15. hotrod1928
    hotrod1928
    from Missouri
    I have a 1928 Chrysler Coupe also, need fenders. Would you be willing to sell the fenders?
  16. El Tortuga
    El Tortuga
    Good to see it on here Austin, been busy I will be in touch. Rock on....
  17. big vic
    big vic
    from cary il
    Keep the 2 leafs its a pretty kool setup
  18. Dale Fairfax
    Dale Fairfax
    Don't screw it up by installing a Ford front end in it. Everybody who builds a non-Ford seems to think they have to change over to Ford's regressive transverse spring when, in fact, the parallel leaves were better. This car screams "keep the fenders", "cut about 3" out of the top", and "install a late MoPar driveline-front to back."
  19. tallhtrddr
    tallhtrddr
    Yes I have decided to keep suspension with parallel springs with dropped axle
  20. bostonhemi
    bostonhemi
    Great looking car. If you already have the hemi just use it theres adapters for long bell housings. Sounds like a good plan but I prefer fenders if you have them.
  21. Gary Addcox
    Gary Addcox
    Hey, tallhtrddr, that Mopar has classy, elegant lines, and will look fine with or without fenders. Really love that understated grille shell.
  22. nitrohemi
    nitrohemi
    i tool 5 inches out of my sedan. looks prefect now. keep the fenders. they have nice lines to them.
  23. tallhtrddr
    tallhtrddr
    Thanks again guys but I do not have all the fenders so not going to run them. But as soon as I get back from turkey rod run going to really get started
  24. Bert Kollar
    Bert Kollar
    I would keep the fenders. Here's pics of a similar car (Dodge Brothers ) with and without fenders.
  25. Bert Kollar
    Bert Kollar
    oops, sorry. Heres one without fenders
  26. tallhtrddr
    tallhtrddr
    Ok guys back from Daytona and thought I would show some updates. Gutted the interior and chopped the top 3 inches with the help of a friend ImageUploadedByH.A.M.B.1386529611.090735.jpg ImageUploadedByH.A.M.B.1386529641.226220.jpg ImageUploadedByH.A.M.B.1386529658.479596.jpg
  27. tallhtrddr
    tallhtrddr
    More ImageUploadedByH.A.M.B.1386529689.536610.jpg ImageUploadedByH.A.M.B.1386529717.180154.jpg ImageUploadedByH.A.M.B.1386529737.681929.jpg
  28. tallhtrddr
    tallhtrddr
    Some more ImageUploadedByH.A.M.B.1386529766.837743.jpg ImageUploadedByH.A.M.B.1386529786.013698.jpg ImageUploadedByH.A.M.B.1386529798.178799.jpg
  29. tallhtrddr
    tallhtrddr
  30. tallhtrddr
    tallhtrddr
    What do you think?
