Features My First Model T
Discussion in 'Traditional Hot Rods' started by Mario.g., Jul 5, 2019.
  1. SS327
    SS327
    Wow! I thought I was giving you good solid advise. I guess I'll just keep my mouth shut then.
    Denny
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    The cup plug in the trans with the threaded hole beside it is where the kickdown cable would go ...what are you doing with the socket ? The cable bracket is reversed , way to close to the throttle shaft ...you've cut your throttle cable to short .. Normally the cable ends up in an "S" shape........AND.......it appears that the top of your tunnel ram is on backwards .....carb base pads are angled to the rear , should be to the front ,....still don't see the inaccessible bolt. ?? You've been waiting for months already , slow down one thing at a time.......
    Its not real smart to piss off people who are trying to help you , remember that in this case , when it comes to hotrods , YOU'RE the dumbass !!
    Maicobreako likes this.
  3. Maicobreako
    Maicobreako
  4. i just went through this with my old lokar throttle cable. Seems like once that cable gets frayed, its time to get a new one. i spent way too much time trying to fish that messed up cable end through the tube. I just bought new...done in less than an hour. That "T" brings me back to when i was a little rodder in the 1970s btw-pretty wicked looking car
  5. Mario.g.
    Mario.g.
    Hey everyone. I wanted to first appologize to everyone. I wanted to also appologize about the gf comment.
    I do know i am the Dumbass in this hot rod situation and I apperciate all the input.
    So i wanted to post a picture up and let me know what you guys think. First i got the bolt out. I removed all the brackets and i flipped the throttle bracket. I flip the throttle bracket and put the throttle sleeve in place. I dont think the throttle cable is going to be able to pull the carbs properly because of how much I had to bend the throttle sleeve. Inside my T is a basic gas peddle. https://www.speedwaymotors.com/Chrome-Steel-and-Billet-Aluminum-Throttle-Pedal,3410.html
    I wanted to get your guys input on this. I wanted to know if you think ill be able to get the throttle cable to pull the carbs properly with the throttle sleeve bent as much as it is?
    Btw the throttle cable bracket is touching the gas line but there's no pressure being applied. Everything fits very snug. Thanks again everyone for all the help and the input
  6. Mario.g.
    Mario.g.
  7. raven
    raven
    If you are setting it up this close to the firewall, then the thing to do would be to have enough length on the cable to do a loop to accommodate the flex you will need and it will work without the possibility of binding.
    r
  8. raven
    raven
    Just be patient and keep asking questions, don’t rush. It’ll work out.
    r
  9. raven
    raven
    Can you post a shot of your valve covers? Just the corner shot looks neat.
    r
