Projects My First Custom - Shoebox Project
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Aug 26, 2010.
  1. EBW
    EBW
    Great Job on the trim work.. How are you getting the tighter radius without messing it up?
  2. 1951Streamliner
    1951Streamliner
    from Reno, NV
    AWESOME!!!! I love where you're going with this car.
    The tires and hubcaps look perfect.
    The chop is perfect!
    Glad you're going with a real stance too, looks so much better than laying on its rockers.
    Also, going the extra mile and doing the stainless will set your car above the rest.
    Cant wait to see it finished...
    :D
  3. the-rodster
    the-rodster
    I'm using an econotig on the lowest setting and it will still blow through if you aren't REAL careful
    Just a hanheld torch with MAP gas, propane would work, MAP gas is faster. Don't worry about discoloring the metal, it will buff out just fine.
  4. mace69
    mace69
    from mass
    Looks great Rodster, glad o see you back at it.
  5. 60srailjob
    60srailjob
    from nowhere
    keep it up man looks good...
  6. 2dr_sedan
    2dr_sedan
    I really like the chop, not overly done.
  7. cavistyle
    cavistyle
    from baltimore
    I'm Notta Ford guy, but Damn man this thing is bitchin. Nice work!
  8. shoebox50
    shoebox50
  9. SloppyEggs
    SloppyEggs
    Man-o-man Its lookin good
  10. the-rodster
    the-rodster
    I'll post some more updates soon.
    I've been installing battery cables, fuel lines, plug wires, starter, distributor, coil, etc.
    Nothing that reallys show, just needs to be done.
    Rich
  11. Looks GREAT!! Nice job.
  12. lorodz
    lorodz
  13. the-rodster
    the-rodster
    By examining my new windshield gasket, I could determine the size of my new glass.
    All the glass templates, ready for the glass shop.
  14. the-rodster
    the-rodster
    I was really pleased at how simple my door latch turned out.
    Works great.
  15. the-rodster
    the-rodster
    Next, I'm tackling the engine compartment, inner fenders, radiator core support...
  16. the-rodster
    the-rodster
    The inner fenders will need considerable trimming.
  17. the-rodster
    the-rodster
    The core support will need a little trimming to clear the steering box.
  18. Johnny Branch
    Johnny Branch
    from so cal
    Damn you killed it on this car, good reading these past 18 pages, I need to get on mine now!
  19. Finnrodder
    Finnrodder
    from Finland
    Wow,a huge update.Nice progress!
  20. ausbuick
    ausbuick
  21. EBW
    EBW
    Great update !!
  22. Buddy Palumbo
    Buddy Palumbo
    I agree - killer update ! Keep up the good work .
  23. mace69
    mace69
    from mass
    Great work Rich
  24. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    What did you use for a brake pedal and mount?
    I got a Cherokee pedal/mount, but the pedal arm itself is too short to mount the booster and master as high as you have yours. To use the Cherokee pedal, the master would have to be mounted over the bead in the firewall just below where yours is mounted.
  25. the-rodster
    the-rodster
    I used an S10 pedal assembly, and yeah I had to lengthen the pedal arm about an inch, but other than that it fits really well and ties into the bottom of the dash.
    Rich
  26. the-rodster
    the-rodster
    Brake lines are all plumbed.
  27. the-rodster
    the-rodster
    For a break, I started polishing the stainless trim, it looks pretty good.
  28. the-rodster
    the-rodster
    The steering wheel was in pretty bad shape.
    There was about ten eighth inch cracks around the wheel.
    Some PC7, sandpaper, and elbow grease, it looked pretty good.
  29. the-rodster
    the-rodster
    Next up was the garnish...
  30. the-rodster
    the-rodster
    Now the dash...
