Features my first custom...'49 ford tudor
Discussion in 'The Hokey Ass Message Board' started by 2345.coupe, Sep 13, 2009.
  1. 2345.coupe
    2345.coupe
    inside the doors are done......
    been sanding the body with 360 grit, found several imperfections that need to be taken care of before I prime her...
  2. daddio211
    daddio211
  3. 2345.coupe
    2345.coupe
    you know what they say..."if you can feel'm, you can see'm"........getting her as straight as I can before I prime her
  4. shooter54
    shooter54
    Wow- nice progress. go man go!!
  5. KustomCars
    KustomCars
    from Minnesota
  6. 2345.coupe
    2345.coupe
    spot putty on....spot putty off....
    getting real close to primer.......then paint.....
  7. cowboy1
    cowboy1
    from Austin TX
    It's looking great! Keep up the great work
  8. skoh73
    skoh73
    Looks good. Following this one.
  9. 2345.coupe
    2345.coupe
    ready to prime.......urethane primer
  10. gwayne
    gwayne
    surely coming along from what I saw when you picked this old fella up... doing a nice job... I am restoring my 1950 coupe also... :)
  11. Bounder
    Bounder
    Man sure looking good, making me want to get started on mine. After cruising season is over, about oct.
  12. 2dr_sedan
    2dr_sedan
    Just read the whole thread, nice write-up, thanks for sharing. Can't wait to see it completed.
  13. 2345.coupe
    2345.coupe
  14. 2345.coupe
    2345.coupe
    base & cleared........few sags in the clear, I'll wet sand later and hand buff them......
    clear coat
  15. KustomCars
    KustomCars
    from Minnesota
  16. 2345.coupe
    2345.coupe
    thanks guys......
    dust settled and paper off......
  17. 62rebel
    62rebel
    just read through this whole thread and learned a LOT that i would soon be asking about otherwise! in the process of dealing on a '51 Tudor and trying to gather as much info as i can... this one thread is a gold mine.
    love the color, makes a chunky car look svelte!
  18. daddio211
    daddio211
    That looks quite a bit lighter green than the stock color. Is it?
  19. 2345.coupe
    2345.coupe
    yup....seamist green......
  20. Shane Spencer
    Shane Spencer
    cool build. like the color choice
  21. 2345.coupe
    2345.coupe
    well, I've learned few things about the flat clear coat. It's the same as using single stage paint. If you have sages,you have to wet sand the sags and re-coat. I had sags in the trunk, hood and one on the side panel.I tryed to compound the spots to blend them in but they were too shinny. Now I'll wet sand the whole car ,1200 grit, re-tape and paper and re- spray. This time I'll pay more attention to the gun settings and address the sags, if any, with a sag file.....
    on the positive side, I'm real pleased the car looks real straight, I was concerned about that aspect...
  22. 2345.coupe
    2345.coupe
    got her all wet sanded with 1000 grit....next take the back bumper off, tape and paper her...
    I decided too also hit her with another coat of color, just to make sure the color is uniform.....
  23. Buddy Palumbo
    Buddy Palumbo
  24. 2345.coupe
    2345.coupe
    prep done....just have to tack her and tomorrow we'll rock-n-roll.......
  25. 2345.coupe
    2345.coupe
    the paint job turned out pretty good.......I'm not too happy with my filler work on some spots. I see I need more light in the garage...but all in all I'm happy with her.....
  26. cowboy1
    cowboy1
    from Austin TX
    Looks great from New Jersey!
  27. daddio211
    daddio211
    Why did you do the paint and bodywork, paint it a stock color, then use a flat clear?
    Please understand, this is NOT a criticism, I'm just curious. Most fellas that go to that much effort want it shiny, or at least pick a custom color.
  28. 2345.coupe
    2345.coupe
    I don't like shinny on a old car or truck... I've always liked the sea mist green...to me it looks like a custom color......
    my next two builds are going to be bare metal body's ,coated with clear coat......
    don't worry about criticizing me....nobody can beat me up better than me.......
  29. daddio211
    daddio211
    Looks great, I was just curious. Please proceed. :D
  30. 2345.coupe
    2345.coupe
    putting on the jewelery.....original '49 grille, mirrors, chrome pieces etc....still have to install the hood rubber mounts before I'll close it tight...
    still working out the bugs.....needs carb re-build, alignment, and some wiring issues to be fixed....
