Features my first custom...'49 ford tudor
Discussion in 'The Hokey Ass Message Board' started by 2345.coupe, Sep 13, 2009.
  1. This ford is gonna be solid. Great thread, thanks.
  2. 2345.coupe
    2345.coupe
    got the dizzy wired in, the turn signal switch wired in and some trunk floor panels welded in.......
  3. 2345.coupe
    2345.coupe
    got the trunk floor completed, waiting on the filler assembly....
  4. cowboy1
    cowboy1
    from Austin TX
    WoW great work! It's coming along nicely
  5. Man oh man, you've made some amazing progress on this car. Stuff like this keeps me inspired to keep going on mine.
  6. daddio211
    daddio211
    Go man go! Can't wait to tear into mine!
  7. 2345.coupe
    2345.coupe
    got the windshield chrome and gas filler assembly installed
  8. 2345.coupe
    2345.coupe
    well, after several hrs. of aliening the the front fenders and hood, we still had an unacceptable gap on the drivers side. Even shimming at the bottom of the inner fender didn't bring it in at the top far enough. It seemed like the radiator support was the problem. I needed to push the fender in at the top more and couldn't do it. After some measuring, I noticed the radiator support was wider at the top than it was near the bottom ,above the curve. I cut a little pie shape piece of metal out of the radiator support just below the lower end of the inner fender. I drew the support over 1/4" towards the center, tacked it, bolted the inner fender to the support and shut the hood.......both sides were ever...welded her up and she's good to go.
    Trunk,doors and bottom of fenders still need some adjustments ......
  9. 2345.coupe
    2345.coupe
    got the '66 mustang radiator mocked in.....I want to use a mechanical fan if I can.....got a shroud coming .Not sure on the width of the fan spacer yet. I'll have to mock it all up to see what's what. Might have to cut the lower valance and definitely have to stiffen up the radiator brackets.
    Have to dig out the grille pieces to make sure the radiator isn't sticking out to far...http://rover.ebay.com/rover/0/e1105...60948171267&ssPageName=ADME:X:RTQ:MOTORS:1123
  10. 2345.coupe
    2345.coupe
    got some of the window trim, and around the lights based and cleared, inside windshield trim partially installed,.......
    mustang shroud installed, bought a 17in., 5 blade fan,with the 1 1/2 in fan spacer, it puts the fan about 1/4 in. inside the shroud..that should draw the air through the radiator nicely.....
    base, cleared and installed the '50 trunk handle......
    also got some more wiring done......
    http://www.ebay.com/itm/110819212286?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
    http://www.ebay.com/itm/170479558233?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
  11. 2345.coupe
    2345.coupe
    I think I found a good place for the electric fuel pump. In this location it can be gravity feed.......I can run the wires through the trunk and on top of the window channels with the rest of the wires......
  12. 2345.coupe
    2345.coupe
    well I changed fuel pumps, I had a summit now I have a airtex 8016s, max pressure (psi) 4lbs, free flow rate 30 gph........I'm running a 302, 2bbl stock carb. I'm still struggling with what's the right pump for my application.....I've searched all the electric fuel pump threads, but still don't know what I should use.....
  13. 2345.coupe
    2345.coupe
    working on the exhaust system......thought I'd try the 14" Porter mufflers.
    going to dump in front of the rear wheels.......
  14. n847
    n847
    Lookin Good!
  15. 2345.coupe
    2345.coupe
    well I went with the mustang "over the axel" exhaust pipes.........
    also fixed the problem of why the deck lid was not closing completely, recessed the lower panel lip...
  16. pointer-1
    pointer-1
    This build is awesome answers many of the questions I have and gives me the absolute in where to go on my 49. I am hoping to do more customizing but base ideas are super. Tearing car apart now and doing evaluation.
    Thanks for the great info !!!!!
    :cool:
  17. 2345.coupe
    2345.coupe
    got the shifter hooked up, all the lights working......just need to get the correct accelerator cable and hook that up, bleed the brakes and hook up the brake light switch, also fab and hook up the trans lines....then start her up........
    then comes the body work and paint.....
    oh yea,also upholster the front seat.......
  18. 2345.coupe
    2345.coupe
    got her registered, insured, runs great...'49 vintage plates,getting ready for paint....going to try my hand at upholstery....
  19. BrerHair
    BrerHair
    Late to the party. Love this build. Well done.
  20. jerseymike
    jerseymike
    car's looking great, just on time for the season.
  21. 2345.coupe
    2345.coupe
    got the front seat upholstered...... used hog rings, burlap,3"seat foam,and dacron batting....
    got the nos ford seat covers......turned out nice.....
  22. daddio211
    daddio211
    Throw a bag pipe in there and you can have a polka party! :D
  23. 2345.coupe
    2345.coupe
    I've never seen this on those car shows......you just see the guy spraying the car, then the finished shinny car......
    getting ready to paint the inside of the doors and jams.......
  24. cowboy1
    cowboy1
    from Austin TX
    What color are you going to paint it?
  25. 2345.coupe
    2345.coupe
    2 stage...base-clear...seamist green..no shine clear
  26. ytt49
    ytt49
    from socal
    where did you get the shifter from and how much was it? if you don't mind me asking?
    I am going to attempt to do my seats in a few weeks.
  27. gotit
    gotit
    If I can give one word if advice I would say pull the trim rings from the head and tail lights. You will get a better finish and the trims will look better when reinstalled.
  28. 2345.coupe
    2345.coupe
    Shifter....I looked up Lokar.com on the net, called the 800 number and asked for the part number for the correct shifter for the c-4, then I purchased one on ebay...$230
    Headlights....That's a good suggestion concerning the headlight rims, I'm going to go with it....thanks
  29. daddio211
    daddio211
    Same goes for the tailights and chrome on the trunk. Just a little more work makes a big difference in the final product.
  30. flatheadpete
    flatheadpete
    from Burton, MI
    I'm doing primer/surfacer on my Shoebox today......should be a good day.
