Hot Rods My car starts but only when I stop cranking it?
Discussion in 'The Hokey Ass Message Board' started by dirttoo, Nov 4, 2014.
  1. dirttoo
    dirttoo
    I have recently got my project car running, well sort of. It cranks and cranks but doesn't start until I release the key. I can crank it a lot or just a little but it won't start as long as I am cranking it. I really don't think it did this at first, seems like it just started doing this. The car is a '60 Falcon gasser type car with a small block Chevy motor. It has a Speedway wiring harness and no original wiring left in the car. The ignition switch is new(reproduction) and my distributor is a used Mallory Unilite with Mallory coil and the ballast resistor on the firewall. I hooked it all up with the instructions from Mallory. Any help would be appreciated. Thanks
  2. 1oldracer
    1oldracer
    It sounds like it is in the ignition switch, that there is only power to the starter not the coil. Have someone check if you have spark at the plugs while you crank it. If no spark either the switch is bad or it is wired incorrectly.
    loudbang and Hnstray like this.
  3. I had the exact same problem with my girlfriends 68 falcon. It was the ignition switch. Took it apart(factory ford) popped the lock cylinder in the new switch. done.
  4. 325w
    325w
    Easy to mess up on the wiring. Never wired a falcon but I've crossed up the wire on a couple of tri 5s
  5. Along the same lines, I would check if the ign terminal has power while cranking, any chance you hooked the ign wire to the accessory terminal that terminal will cut out while cranking.
    Since there is usually another circuit that powers the coil while cranking and given that it doesn't fire while cranking, did you wire in the ballast bypass from the starter solenoid or is that not needed with your Mallory set-up?
  6. low budget
    low budget
    from Central Ky
    I think you need to run a wire from the S terminal on the starter solenoid to the coil wire in conjunction with what you already have "If I remember correctly"
    Old wolf likes this.
  7. squirrel
    I think both of the last two posts are correct. Make sure the ignition switch wiring is correct, not on the Accessory terminal. And add the wire from the coil + terminal to the starter S terminal.
    Old wolf and Black_Sheep like this.
  8. bct
    bct
    you need to feed the coil and the start solenoid when she is cranking. if your ignition is good you need a short jumper from run to start. while cranking the ignition bypasses all circuits(headlights . radio , etc) except coil and solenoid . you aren't getting power to coil until you let go of the momentary part of the ign.
  9. sport fury
    sport fury
    the ignition switch switches to 12 volts at the coil to start. and when you let off the key it switches to run 6 volts to the coil. it uses a ballast resister to drop the voltage down. you could have a loose or disconnected wire at the ballast resistor. it is also possible you have a bad connection at the ignition switch or a bad ignition switch
  10. Ryan said it was goin to get weird around here.
    SwampLedge likes this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    Could also be the solenoid's start bypass to the coil is bad. Ford solenoid's are real cheap and easy to hook up. Get a new one.
    Jack E/NJ
  12. low budget
    low budget
    from Central Ky
    Hes got a chevy in it.
    Built ford tuff with chevy stuff:D
  13. The "I" terminal on the starter solenoid needs to feed the ignition
  14. Or maybe a bad ballast resistor?
    Charlie Stephens
    Dago 88, irishsteve and sport fury like this.
  15. My experience with a bad ballast resister has always been the opposite (GM stuff). It would try to start while cranking but as soon as you let off the key, it wouldn't run.
    I agree with others it sounds like maybe you have the ignition connected to the wrong terminal on the switch or you've got a bad switch.
    Hnstray and sport fury like this.
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    No, this is a very common problem with a sbc engine. You have two small terminals on the starter solenoid and one large terminal. The big one is for the battery cable and the small one to the right of it is for the S terminal (start terminal) on the ignition switch. The small terminal to the left of the big one is what is causing your problem............you need to run a wire from that terminal to the + terminal on the coil. So, when you are cranking the engine it feeds a pure 12 volts to the coil to fire the motor, then when it gets started and you release the key from the start position, the ignition terminal on the switch will continue to feed voltage to the coil to keep the motor running.
    Run that wire and your problem is solved.
    Don
    bct likes this.
  17. Ulu
    Ulu
    from CenCal
    Yes, the ballast is only used while running. It's bypassed (
    by the solenoid) while starting, to get more coil voltage.
  18. S for start - this is the trigger wire that activates the starter
    I for ignition- this provides 12 volts only while cranking
  19. If by some chance you ran a wire from the coil to the S side the starter will try to activate usually with 9 volts.
  20. low budget
    low budget
    from Central Ky
    So its the I or R terminal that goes to the coil and not the S
    ...........Beat me to re writing my post ........
    But anyway while we are here, Would that work on the S post but not let the engine run rite (with only 9 volts)and/or would the S not let you shut engine off using the switch?
  21. One more time-
    Powering the s terminal makes the starter do what starters do.
  22. Mr48chev
    Several of the guys detailed it pretty well and pretty completely.
    In simple terms while "some" switches send power to the coil trough the ignition pole on the switch there are some that don't and those rely on the resistor bypass wire from the "I" post on the solenoid running to the coil to get 12 V to the coil and then when you let the switch go back to "run" the power runs through the ign circuit in the switch to the coil. It is fairly prevalent in aftermarket "universal" switches from my experience. It seems that you got one of those switches and then wired things wrong from what I see above.
    Side note: I've had to run a wire from the I post on the solenoid to the HEI on a couple of rigs friends had the same problem with when they did HEI swaps. Both had no power to the distributor when cranking because of the way the switch was set up.
  23. Jack E/NJ
    Jack E/NJ
    from NJ
    lb>>>Hes got a chevy in it. Built ford tuff with chevy stuff:D>>>
    Yep. I got a 265 and a 413, and neither of them have the PIA solenoid on the starter anymore. Both starters are fed with the Ford solenoid. And so is the starter on my old Case tractor. Jack E/NJ
    Nitroholic likes this.
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    You are making this way more complicated than it needs to be. Here, I made you a drawing. Wire it this way and it will start and run.
    Don
  25. low budget
    low budget
    from Central Ky
    Yeah Ive got it,Sorry to confuse the situation, Like I said in the quoted/deleted post of mine Ive built and wired that part on 3 (make that 4, I forgot one)55 chevys that had the same issue of not starting until you let off the key.
    I was thinking it was off the S at first,maybe I was wrong, no biggie, please excuse:rolleyes:...:)
    I may have gotten squirrel confused too cause he agreed with me???
  26. Ulu
    Ulu
    from CenCal
    Just as an aside (like we haven't had 12 yet) if you get the I & S wires switched the car will start but the starter won't quit running.
    I had one genius do this on his '61 Caddy, and then to "fix" it he cut the wires under the dash and switched them too!
    Then he brings the car in the shop saying "it runs OK but doesn't want to start, even with a brand new starter."
    Well yes, the ignition was trying to start the car "on the ballast"! He wasn't as smart as he thought when he switched the wires under the dash because he was too lazy to jack it up and crawl back under.
    I got under, saw the switched wires. It's frikkin obvious: the S wire and S terminal are both thicker than the I wire & terminal! How do you get that wrong???
    So I corrected the wires at the solenoid, with the result that I had to find the cut wires under the dash & fix them too to stop the starter.
    Of course the owner never told me he cut & switched wires around. That might have saved him $10 labor ($50 now, This was 1972) because I wouldn't have had to search the car to find the cut & spliced wires.
  27. Paul M Cochran
    Paul M Cochran
  28. Ebbsspeed
    Ebbsspeed
    @Paul M Cochran , please do an intro, and try not to dredge up old posts.
    After nearly 5 years of age since the original post, he probably got it figured out.
  29. squirrel
    Or "start a conversation" with Don.
    (it's not a blank post, he asked a question: "Don
    a few years ago you posted a drawing of how to wire.... do you still have that and can i get it from you, i have another project and lost the original you posted.thanks,
    Paul")
    lothiandon1940 likes this.
  30. Malcolm
    Malcolm
    from Nebraska
    Unfortunately, it looks like Don hasn't been active here for a couple years. Like yourself, Jim, he was good at helping folks around here... his presence is missed.
