My buddy's Detroit Diesel pwd 23 T bucket!
Discussion in 'The Hokey Ass Message Board' started by HotRod60F100, Dec 4, 2011.
  1. HotRod60F100
    HotRod60F100
  2. BIG-JIM
    BIG-JIM
    from CT
    Well I'm speechless.:eek:
  3. shootingmonkey
    shootingmonkey
    Very cool. I always enjoy seeing odd or unusual powerplants in rides.
  4. Taff
    Taff
    i can't see this ending well....
  5. Flynn's_57
    Flynn's_57
    from Nor*Cal
    'Willickers... Now just run it on veggie oil and win over the hippies!!
    oh! and....
    "kinda 'rat-roddy' for the HAMB",
    :D
  6. stainlesssteelrat
    stainlesssteelrat
    from ms
  7. n.z.rodder
    n.z.rodder
    X2.
    Scotty
  8. No words right now.... wow.
  9. lostforawhile
    lostforawhile
    maby not to everyone's taste, but still cool, monster motor T bucket, whats not to love? the sound of that thing hauling ass in the video is unreal. It needs a video shot from INSIDE while it's hauling ass :D
  10. AlbuqF-1
    AlbuqF-1
    from NM
    That engine's got to weigh 900 lbs??
  11. 6V-92 in a T who would have thought! Now all he needs is a twin turbo set up, some big injectors and a little nitrous and see if he has the balls to lay into it full throttle and stay in it!!
  12. bb1970
    bb1970
    That engine probably out weighs the rest of the car.
  13. Dynaflash_8
    Dynaflash_8
    from Auburn WA
  14. More than 2000 lbs if I remember right.
  15. Six-Shooter
    Six-Shooter
    from Ohio
    It gets my vote as fan favorite! Wow!
  16. tommyd
    tommyd
    from South Indy
    OK, I'll bite.....what trans is he using? .....16spd?
  17. movingviolation
    movingviolation
    Thats on huge chunk of engine squeezed in there....
    It has to hit like a tank... suspension and frame are going to pay the ultimate price i fear..
  18. I believe it is a 6V-53 engine... still looks interesting.
  19. hotrod_32
    hotrod_32
    Wow ! Not sure what else to say. looks like a 6-53 to me also,the 92s were a bigger engine .
  20. anteek
    anteek
    Always liked a V-6,but he needs a larger rear to handle the torque.
  21. A classic example of: "Just because you discover you can do it, doesn't mean you should do it"...
    Oh well, I'm sure he's enjoying it, and more power to him.
    Tick....tick....tick....
  22. khead47
    khead47
    I think he could forget the transmission other than the need for reverse!
  23. oldcarfart
    oldcarfart
    different on many ways, driver's visability sucks, eh?
  24. chopper cliff
    chopper cliff
    from lodi ca
    Definitaly a 6-53, don't use nitrous, use propane thay like it better, old Detroit mech I used to know said if you want to run a Detroit, first thing you is slam your hand in the door and drive it "PISSED OFF", I like it , shows that you march to the tune of a different orchestra , I got the injector tools!!!!!
  25. flatheadpete
    flatheadpete
    from Burton, MI
    I'd like to know some frame specs please.
  26. banjeaux bob
    banjeaux bob
    from alaska
    They were running some Terex scrapers on the North slope with V-12 s in them.The shop had on run a engine overhauls.The tops of the pistons were burned.One of the mechanics in an attempt to discover the cause took a couple of breaks with the drivers.As the conversation progressed,the cause of failure became apparent.
    The drivers were discussing who won and lost the previous shift's races.one of the drivers mentioned "passing gear".What they were doing is grabbing CASES of starting fluid from the parts room.Then when a race materialized,they would spray the fluid into the air intake.I guess when that engine got to breathing air,diesel,and joy juice at top speed it was like another gear!
    The mecahnic then looked behind the seat ,only to find previously aforementioned case of starting fluid!
  27. Yep my bad, i forgot the 92's have the valve cover bolts on top of the cover. but still impressive!
    No propane it is like adding more fuel, it raises egt's, nitrous will burn the extra fuel and not raise egt's and if you go to much it just puts the flame out. totality different than on a gas motor.
    And another thing i don't get is why the crybabies bitch when someone builds a rod and puts a diesel in it and want the mods to delete the post as off topic, no different than putting a damn small block chevy into a Mopar. It's a motor after all!
  28. And we wonder why the price of gas is so goddam high....:mad:
  29. lostforawhile
    lostforawhile
    coolest diesel project since [​IMG]
  30. nailhead terry
    nailhead terry
    Those damb detroits will run backwards if they kickback when being started that would be fun !! cool deal what trany ?
