Its a 55 dodge with a red ram motor and auto trans. The front end is out of a early 60's ford 1/2ton. If I can get the motor to run ill keep it in there. If not Ill transplant something else. Just thought Id share and see what HAMBERS had for advise.
Thats bad ass , Looks cool with the front up in the clouds, Love the motor and it don't look like it would be to hard to get it running, Is the motor stuck will it turn over by hand ? If it will, should be easy from that point, air spark and gas good to go...
The motor is free and the plates on the car are only 3 or 4 years old. The owner went to jail abou 3 years ago and my boss gave me the car.
looks cool.poly motor should stay if at all pos.are you going to make it a street-strip?cage?looks like a pretty heavy car,if making it drag there is going to be alot of work shedding about 1000 lbs.have fun!!
Thats kinda what I was planning on. Im going to try and cut as much weight as possable. I am also planning on a roll bar.
