my 56 Town Sedan "under a tree" find
Discussion in 'The Hokey Ass Message Board' started by F91, Feb 22, 2013.
  1. Good find. I have become somewhat partial to 56's since I got mine a couple years ago. Sounds like you are making progress.
  2. F91
    F91
    Thanks again all. 57 custom 300, I think you nailed it. I cut the power steering belt off today and topped off the cylinders with ATF. Gonna let her soak a bit more.
  3. Redlighting
    Redlighting
    from Tn
    ..............isn,t that a later model carb also????
  4. junkyardjeff
    junkyardjeff
    It has the correct 56 4 bbl carb.
  5. No it looks like a typical teapot carb AKA towering inferno. Have a fire extinguisher handy when you "fire" it up the first time.
    My burst into flames after a backfire a few months back. Luckily no real damage occurred.
  6. F91
    F91
    It is a period correct 56 4 barrel teapot. Bomb - good to know!
  7. Yea, good advice on the carb...l am just looking forward to replacing mine with 3 Holley 94's...
  8. I'm replacing my firepot with an Autolite 4100 from 1957 with 1.08 venturis and a B manifold. I'm going for a period correct swap.
  9. F91
    F91
    I'm still waiting for my "magic potion" of ATF/acetone to loosen her up. Been trying a breaker bar on the crank bolt, but I'm not too crazy about that. My friend suggested putting the generator belt back on, tightening it up and using the fan to hand rock the crank back and forth. It's only been a couple of days, but I'm open to suggestions.
  10. Reman
    Reman
    from Florida
    It may very likely have a bunch of stuck valves. I would pull the rocker arm assemblies from both sides. Then the crank assembly could turn easier and you could check each valve for being stuck. Good luck...I love 56's
  11. F91
    F91
    Good idea Reman. Sounds like a plan for this weekend.
  12. Awesome!
    I love my '56 four door. If you go with 3" blocks on the rear it will ride on the bump stops on rough roads. What I did was use Gabrial High Jackers and an Air Lift compressor paid a little over $100 for the whole shebam on Amazon. Also get youreself a '57 Intake with an adapter and a newer four barrel carb. They are super fun cars though! I have fallen in love with them ever since I got mine! Oh yeah also get a '57 and up dizzy for her!
  13. F91
    F91
    Good advice Mitchell. I was thinking Petronix for the distributor, but a 57 setup at minimum. I like the rear end advice too.Are you saying you used the high jackers WITH the lowering blocks for rough roads?
  14. If the engine still won't turn ovet, pour some MMO inside the block to "pickle" the engine. I did this, and it spun over very easy after letting it sit for a week.
    Dave
  15. F91
    F91
    I just need to be patient. I didn't really have the pistons covered with ATF till mid Tuesday. If all else fails, I will be trying everyones suggestions.
  16. F91
    F91
    Still waiting. Added some diesel to the mix today. Also found the original rocker arms in the trunk. Original owner came by and said that the rebuild on this engine probably has about 300 miles on it! 300 miles and you let it rust under a tree. Damn it!
  17. It makes me wonder if something else started acting up after the rebuild. It takes a lot of time, effort and money to do all that. It seems odd to do all that and then park it under a tree and let let it rot.
  18. F91
    F91
    The owner I got it from was the son of the guy that had it rebuilt. The rebuild- owner passed away not long after the rebuild. The car did need a new generator and it ran rich when they parked it. The pallbearers rode in this car at the funeral.Other than that, it's supposed to be fine.
  19. That's a sad story. My car's PO passed away not long after he bought it from the original owner. Luckily my car was kept in dry storage, but for over 12 years until his widow was finally pressured by her family to let it go.
  20. F91
    F91
    Update: Nothing. We are building a house, so the last few days, weeks, have been reserved for priming and painting the inside of our house. Never prime and paint the inside of your house. Hire someone.
  21. F91
    F91
    Frustrated. Started looking at 292's,312's and 302's on CL. May have a line on a 64 F100 with a 292 , running, for 500$.
  22. hotrodjim
    hotrodjim
  23. F91
    F91
    OK, Fine!!! Meet this 64 F100 that my buddy scored:
    Has a running 292. Has the updated single vacuum dizzy and a 2bbl Holley. I get the motor, he gets everything else. Eventually, I'm gonna tear my old 292 a new asshole.
  24. TrioxinKustoms
    TrioxinKustoms
    from Romney, WV
    cool car, I put petronix in my 61 caddy and my grandfathers 63 thunderbird. It was really easy and so far so good.
  25. rustydibris
    rustydibris
    would be cool to try and get the engine un seized and maybe try to fire it up
  26. JeffB2
    JeffB2
    from Phoenix,AZ
  27. Seller of the Mustang engine says it still needs to be gone through so the 64 engine is still the best bet.
  28. woodbutcher
    woodbutcher
    :D Good score.Like my Grand Father used to say."Slow and sure beats the hell out of quick and dead".
    Good luck.Have fun.Be safe.
    Leo
  29. F91
    F91
    Jeff - that 302 is in Idaho, about 5 hours over and 5 hours back in my F250. Not fun (or wallet friendly)! My buddy is going to pull the 64 292 and drop it off at my house. The 64 has the single vacuum advance dizzy in it already, so that's a good start.
  30. F91
    F91
    It will get the heads pulled and hopefully get un-seized. It's too nice of an engine to let die.
