Projects My 52 Fleetline Project
Discussion in 'The Hokey Ass Message Board' started by Slide, Apr 19, 2009.
  1. Slide
    Slide
    Well, lookie here! I actually got something done! Just finished welding up this crossmember assembly for the rear upper shock mount. The curved ends will get welded to the top of the frame rails, and the beige bar is just a temporary brace to keep things from moving around while welding.
  2. Slide
    Slide
    Got the lower shock mounts welded & gusseted on the trailing arms. All those compound angles took a lot of trial-and-error fitting!
  3. PeteFromTexas
    PeteFromTexas
    Any more updates???
  4. big creep
    big creep
    this car is going to be bad! i want a fast back bad!
  5. nailhead ed
    nailhead ed
    awesome job slide...I'm doing a pontiac silverstreak currently which is very similar to a fleetline...check out bass kustoms for some ideas...he's done a couple of bitchin fleetlines...keep up the good work
