Hot Rods My 41 Chevy P/U Build
Discussion in 'The Hokey Ass Message Board' started by swade41, Jan 9, 2010.
  1. Dooley
    Dooley
    from Buffalo NY
    Didn't take long to get that on there!!
  2. Fullfendered
    Fullfendered
    Did you fire it up?
  3. RAF
    RAF
    from MA.
    Love the stance!!
  4. Hamtown Al
    Hamtown Al
    1. Virginia HAMB(ers)
    It's coming along.
    Keep workin'
  5. What a nasty little piece of work - I love it!
    Subscribed .... :)
  6. Did ya know a 555 Ci with aftermarket block is practically the same price as a 496 using a stock block. I'm sure my Edelbrock rpm heads won't support full boogie on the 555 but what the hell.
  7. bW1jMS9EQ0lNLzEwMFNTTUVEL1NTUFgwMDMzLmpwZw_zps6b1b1dcd.jpg Ok now I'm committed to actually having to get this thing on the road, I just ordered a 540 short block ! I got it turned around so engine removal can be accomplished, oh man....what have I done
  8. Dooley
    Dooley
    from Buffalo NY
    clean the bed out, looks like Sanford and son
  9. Dooley
    Dooley
    from Buffalo NY
    what are you going to do with the other big block? The one currently in the truck? it';; fit in the J
  10. Last edited: May 13, 2015
  11. 10990877_10203412604704544_6994654908749872464_o.jpg 20150503_175746_zpslglvz7mh.jpg 20150503_175808_zps466bbivs.jpg Since welding isn't recommended for me, I dropped the beast off to have a new coilover ladder bar rear to handle the new power
    Also stripped the filler off the cab to see how bad it actually is
    Dropped it off at Old Soul hot rod shop to get that fixed. I'm going to drive this prick before my health gets any worse !
  12. You rich guys got it made!-MIKE:p:D
  13. Dooley
    Dooley
    from Buffalo NY
    that's an awful big sunroof....what are the plans for front lights and grille?
  14. IMG_07141_zps7srwmet0.jpg IMG_15971_zps0svpboep.jpg IMG_07341_zpsx6vj4dlw.jpg Test fitting the new roof section
    Needed some slicing so the guys sliced
  15. IMG_07331_zpsezl7n18a.jpg IMG_66411_zps3n3adikq.jpg IMG_45461_zps1your95w.jpg IMG_15311_zpstelgqvlb.jpg IMG_66411_zps3n3adikq.jpg IMG_66411_zps3n3adikq.jpg IMG_07331_zpsezl7n18a.jpg IMG_66411_zps3n3adikq.jpg The rear lined up and tached into place
    Moving to the front tomorrow
    They sure did a great job on it !
  16. 20151009_142741_zps5b132h9x.jpg 20151009_163459_zpsndg7dj5s.jpg 20151009_185521_zpszlpxh4kx.jpg 20151011_112915_zpshajwyfx2.jpg My health isn't getting much better, they scheduled an EBUS for something they spotted in a heart CT scan. Like I need anything else on top of the current issues. Lets hope for it not being what it could be.
    I've went through and removed a bunch of the OT photos and feel the low budget tech is still pretty good here. I found a painter and started putting the truck back together to make sure all the one off pieces were finished enough. The day before it was to be picked up I decided to go ahead and cut some holes in the welded in tailgate, something I had been thinking about for a few years. Trying to decided on the proper size and spacing of the holes.
    Going for broke with the hole saw, I like it !
    and off to paint, same black with a satin clear for that sinister look
  17. FB_IMG_1507816328115.jpg FB_IMG_1507816380620.jpg FB_IMG_1507816365376.jpg FB_IMG_1507816412276.jpg 20151015_155541_zpsw8l7rse7.jpg I kept the front end here, it still needs fitting for the blower stuff poking out of the hood
    I glassed the hole closed I had cut out for the Moon tank, repaired lots of cracks also, battling fatigue but pushing forward.
    Then marked it out for more speed holes !
    I'm running Moon discs, with a silver belt line trim as well as a silver painted area along the lines of the stock grill shape.
    volvobrynk likes this.
  18. Dooley
    Dooley
    from Buffalo NY
    looks great
    good luck with the MD as well...
    droppedstepside likes this.
  19. The 'like' button just didn't feel right. Looks like good progress to me. That engine looks awesome!
    volvobrynk and swade41 like this.
  20. Was on the dyno Wed. And Thurs. new meaning to "speed" holes.
    8.2 % over driven made 3.2 lbs of boost which made 706 hp at 6000 rpm and barely climbing and 746 ft lbs tq at 4400 rpm on pump gas. The air yesterday in the room was worse than on Wednesday and showed a loss of 34 ft lbs @4500 and 62 hp @6000. The only difference being Wed. at 34 degrees timing and Thursday at 32 degrees. Plenty safe tuneup at only 3 lbs boost so it should live a long time. At 2500 rpm it was making 631ft lbs, at 3500 it was 702 ft lbs and carried over 700 till 5000 rpm at 702, still had 618 ft lbs at 6000 rpm 20151029_185736.jpg
    Dooley likes this.
  21. Dooley
    Dooley
    from Buffalo NY
    that's going to be a bad ass truck....
    swade41 likes this.
  22. 20151105_124958.jpg Stopped by and checked the progress on the body, it's coming along. I go in for the biopsy day before Thanksgiving and hope to get it back before that.
  23. I had a friend machine me some new motor mounts to replace the rubber biscuits. 20151106_143021.jpg
    I put the flex plate and starter on the engine then checked the convertor fit to flexplate. The convertor came out of a car with a mid plate so wasn't sure if the nose of it would bottom out on crank.
    Today I chased bolts across town to get the water pump on and it's pulley. It all lines up good. I thought I had a steel pulley but only had one that was to big, so this one will do. 20151106_155632.jpg
    Dooley and Chucky like this.
  24. Dooley
    Dooley
    from Buffalo NY
    looks great...good luck prayers sent...
    droppedstepside and swade41 like this.
  25. bubba55
    bubba55
    Your future ride looks great - prayers sent as well - Be like Mr. Natural - Keep yer sunny side up !
  26. 20151130_130055-1.jpg 20151130_141057.jpg 20151130_125127.jpg 20151203_151749.jpg Got the truck back from the painter but the paint job is full of runs, dry spots and shoty work. Really sucks to say the least but I decided to bolt on the fenders and running boards to see if my build vision was there or not.
  27. The firewall actually looked good so I installed the engine/Trans to keep my mind busy while waiting on the biopsy results. They said 10 days on that so I'll keep moving along on it.
    The hole I cut in the hood didn't fit the new scoop so I started cutting that bigger and screwed my back up. I had ordered some new parts from Summit and of course they came in but that'll have to wait. 20151202_175238.jpg 20151204_121632.jpg 20151204_183025.jpg
  28. Dooley
    Dooley
    from Buffalo NY
    like the all black, hope you get the paint sorted out.
    Truck should haul ass...
    Positive vibes sent for the heath...
  29. Like a dumb ass I cracked the new transmission's case putting the A-N fittings from the old Trans into it. Some th400's were pipe and others straight, lesson learned that it doesn't take much force to Crack the case.
    So out came the engine and Trans to replace the Trans case. 20151216_111252.jpg
