Projects My 392 Hemi Model A roadster build
Discussion in 'The Hokey Ass Message Board' started by Oneilfab, Dec 5, 2012.
  1. Yeah it's going pretty good but it's forced me to take a three year hiatus from my Tee. Oh we'll. starting to make some headway with it again.
    You got a color picked for your roadster?
  2. Oneilfab
    Oneilfab
    Right on, i'd like to see it, got any pics of it?
    i have no idea what color i'm going to paint it yet, all i do know is i'm going to run a set of '35 ford wires painted black with a chrome center cap and tall, skinny black wall tires.
    kiwijeff likes this.
  3. Oneilfab
    Oneilfab
    Been busy for the last few days working on the frame, got most of the inner structure tacked into place, still have some temperary cross members to cut out, waiting until everything is fit up and tacked into place before i cut them out
    borrowed a friends tubing notcher, saves so much time
  4. Oneilfab
    Oneilfab
    Spent most of the day building a rear crossmember to mount the coil overs too. been using 1 5/8" .120 wall mild steel tubing
  5. GaryB
    GaryB
    from Reno,nv
    damn thats nice,
  6. HILLBILLY HOT RODS
    HILLBILLY HOT RODS
    Where can i buy one of these :cool:
  7. Oneilfab
    Oneilfab
    Cut out the temperary crossmembers and cleaned up the tack welds and got some better pics. still need to build a trans cross memeber, going to have to wait until after christmas for that tho
  8. farmer12
    farmer12
    Great craftmanship showing here, love it. I may just build one of these when I'm finished with my present project. Keep up the good work!
  9. Awesome. You are making it look easy!
  10. Hey Neil, I really like the rear Driveshaft Loop! Looks Trick!
    Hope you like the Bench Grinder/Sander...Merry Xmas! :D
  11. awesome! nice work!
  12. Oneilfab
    Oneilfab
    built a trans cross member yesterday,made the center removable, welded 90% of the crossmember, going to tig weld the rest of the frame once all the fab work is done and i can take it apart and put it back on the table
  13. TheTrailerGuy
    TheTrailerGuy
    That should be one viciously fast and fun little ride.
  14. BuiltFerComfort
    BuiltFerComfort
    This looks well thought out.
    Denso makes a tiny alternator, I forget what Mazda it's for.
  15. bostonhemi
    bostonhemi
    The hemi with the chassis ... man oh man is that ever nice!
  16. Oneilfab
    Oneilfab
    Thanks! cant wait to get some nice wheels and tires on it, have to wait until the portland swap meet to get a set tho:mad:
  17. BrerHair
    BrerHair
    Fantastic work!
  18. junkyardgenius
    junkyardgenius
    from Kernow
    Got to agree with that. Nice headers too, did you make them or buy them? looking for a set here.
  19. Oneilfab
    Oneilfab
    Thanks! the headers are sanderson, i also have a set of flanges and i'm going to make a set of zoomies or lakerster style headers just for start up, dont want to wreck the seramic coating on the sandersons on first start up, seen it happen before...
    Happy New Year!:D
  20. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Looking good. Can I ask why you didnt center the pinion? It appears that the engine and trans are centered in the rails.
  21. Oneilfab
    Oneilfab
    the motor and trans are centered in the frame, the rear end is also centered but yes the pinion is not, the rearend is from a 1966-77 bronco, its 58 inches wide, its the perfect width for the car, the reason i didnt center the pinion is that i found this 9 inch locally and i didnt want to spend the $1000-$1500 to narrow a rearend, i'm building this car in my shop as i can afford it and it just wasnt in the budget so used what i had. i agree it would have looked better with the pinion centered but once the body is on you will never see it! lol
    Happy New Year!!:D
  22. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    I thought that might be the case. ;) It is looking good.
  23. Oneilfab
    Oneilfab
    Was bored today i decided to dress up the brake and clutch pedals with some holes and built a few gussets to support the bars that the 4 link is welded too
  24. Oneilfab
    Oneilfab
    Got my new duvall widshield frame dropped off today, couldnt wait to get it on the car, think its really going to look good on the car when its done
    made a template for the mounting holes
    rigged up the body so i can lift it on and off by myself with the engine hoist
  25. Oneilfab
    Oneilfab
  26. farmer12
    farmer12
    WOW! Thanks for posting the pics! Looking awesome!
  27. The37Kid
    The37Kid
    That's looking great. Hope mine looks as nice a a year or two. Whos adaptor did you use fro the transmission and what is the bellhousing from? Bob
  28. Oneilfab
    Oneilfab
    Thanks!
    the adapter is from Hotheads and the bell housing is a original GM 11 inch from a 69 ish big block camaro, the trans is a muncie M21 from a 68 nova
  29. Enjoying your build thread, great to see.
    Quick question if I may, did you extend the wheelbase at all, and what sort of length is that engine bay to say the centre line of the front crossmember, curious as I'm helping a friend with his 31 coupe(with 331/T5), and your stance and component placement certainly visually work without looking awkward.
    Cheers,
    Drewfus:)
