My 37 Ford pickup build thread by clips221
Discussion in 'The Hokey Ass Message Board' started by clips221, Jan 14, 2011.
  1. falcongeorge
    falcongeorge
    from BC
    looking good. Glad to see more of these trucks being built with thier fenders.
  2. MATACONCEPTS
    MATACONCEPTS
    Check out this 37 Im building "HomeBrewed" Style
  3. aerocolor
    aerocolor
    from dayton
    I`ve got one going too. I`ll be watching your progress.
      434 KB
      491.2 KB
      465.6 KB
  4. clips221
    clips221
    Got the engine n trans bolted in place this weekend. uploadfromtaptalk1349643292208.jpg
    Sent from my DROID device using the TJJ mobile app
  5. clips221
    clips221
    Engine and transmission installed. Set the cab, fener n running board on to check fit.
  6. Von Richthofen
    Von Richthofen
    Looks like you have a good build goin
    Here,s my 36 keep us posted
  7. hotcoupe
    hotcoupe
    i hope i live long enough to finish mine.
  8. clips221
    clips221
    Working on the doors. Adding patch panels to the bottom
  9. clips221
    clips221
    Been working on my doors this week. Fitting patch panels. It's a learning process.
  10. Looks like you are making good progress,,did you fabricate the patch panel on the back of the cab? HRP
  11. Looking Good! Where did you purchase the patch panels?
  12. clips221
    clips221
    the door patch panels actually came with the truck when I bought it a couple of years ago. they can be bought off of ebay. fit is decent. Having a hard time with the door skin wanting to warp, 100's of tach welds toghther.
    HRP, I bought the back cab panel off ebay. It fit very good. the cab corners were a decent fit.
  13. clips221
    clips221
    got both door inner and outer patch panels installed. still gotta hammer and dolly them out. they turned out pretty good.
  14. clips221
    clips221
    Been doing some patch work on my fender. that outside bottom trim roll is a challenge. One fender is getting close to being patched up.
  15. clips221
    clips221
    Got the fenders all patched up and have been working on my grill. I took 2 grills and made one decent grill. I'm proud of the way it turned out. It's a learning process. The front end is hung on the truck to check for fit before the cab goes to the paint shop.
  16. Looking great man!
    Nice that you're going full fendered...
  17. clips221
    clips221
    Making some good progress on the cab. One drip rail was gone and the other was in very bad shape. here's a couple of pics of the new drip rails a friend's fabed up. Hoping to have the cab and doors in paint in a week or so.
  18. manyolcars
    manyolcars
    You were pretty lucky to find rear fenders in any condition. I looked for rear fenders for twenty years. I learned that everyone else was looking too.
    After looking for 20 years, every year at Pate, I found 5 at Pate at the same time then got two more out of Arkansas. When it rains, it pours.
  19. clips221
    clips221
    I ran across a few dollars and am back on my ole truck. Got the 327 engine cranked up this past weekend.
    I'm working on trying to figure out my wheels, back spacing, etc.. I'm gonna run a 15x6 up front and either a 15x7 or 15x8 on the rear. 4.5 bolt pattern. I put the bed sides on and a rear fender. Measuring from the face of the drum to the bed side is 6". thinking maybe a 4 or 4.5" back spacing??? any suggestions?
  20. Jeem
    Jeem
    Alliance Vendor
    The drip rails look fantastic! I'm going to need to do something for my passenger door.
  21. clips221
    clips221
    My attention span has came back around to my 37 pickup... I'm gonna start working this weekend on running my brake lines and fuel line. I have ordered an alternator bracket from southern rods that should work with my setup.
  22. clips221
    clips221
    Got all the brake lines ran this weekend. I added an adjustable proportioning valve to the rear drum brakes as well as a 10 lb line lock on the rear line and a 2 lb line lock on the front disc brakes.
    Also started working on the rear fender patch panels. All the rest of the body has the patch work done accept for the rear fenders. Getting closer....
  23. clips221
    clips221
    This is how both the rear fenders look where they join the running boards. Got one side cut out.
  24. You have made a ton of progress,,but it looks like the rear fenders need a little more work..your almost there! :) HRP
  25. JLB3
    JLB3
    Looks great!
    How did your friend make the drip rails? They took em off my 37 pickup too but I would like to add them back.
  26. clips221
    clips221
    Got a little bit done on the fender yesterday.
  27. pinupwithgun
    pinupwithgun
    Nice! I drive the snot out of mine.
  28. clips221
    clips221
    Ordered my wheels from summit. 15 x 7 rear and 15 x 5 front. Smoothies.
  29. clips221
    clips221
    My smoothie wheels came in yesterday. Either gonna get them powder coated or do a base coat clear coat on them.
    Still working on the rear fender patch's. didn't realize there was so many contours and curves to these fenders until you start shaping and forming a flat piece of sheet metal. Copper flashing behind where your welding... that's the secret to help from burning through.
  30. clips221
    clips221
    Got my wheels painted. Snapper red.
