Hot Rods My 34 roadster....sorta
Discussion in 'The Hokey Ass Message Board' started by Clark, Jul 10, 2012.
  1. general gow
    general gow
    MODERATOR
    i can imagine it. gives me a jumping off point, anyway.
    thanks clark. looks great.
  2. Clark
    Clark
    Got some more done on the car....ben working on the dash and the transition from cowl to dash. I finished the top of the cowl but didn't have the roll under done. When I did the roll under I put a flange in for the dash to bolt to. The dashis a stock closed car dash reworked to look like a roadster. Also mounted a 36 column drop and a tube for the column.
    Also got one of the seats mounted. It's a bus driver's seat from a 50's GMC bus. Yes I have a match....try finding matching bus driver's seats. They're pretty cool. the seat back is adjustable by picking it up and sliding it front and back. It sits in little slots. The angle can be changed too. I did everything I could to mount it as low as possible.
  3. Uncle Jess
    Uncle Jess
    from Western Ny
    Always fun to see what your up to Clark, looking good Holmes keep at it. Jesse
  4. HomemadeHardtop57
    HomemadeHardtop57
    Man I love those clecos, they make life so much easier
    The dash looks great
  5. bonesy
    bonesy
    I'm digging those seats. Cool!
  6. Clark
    Clark
    Net area to get attention area between the trunklid and the cabin area. It took two pieces to make this area. I think I made thi area about 2 inches shorter than a stock roadster. Mine is about 6 inches.
    Here it is done except the top lip gets folded over an inner panel.
    Today I got my doors back from the blaster and couldn't help but to start the top of the passenger side. I got the outer part on but there's a lot of hammer a dolly work to do yet. Then I have to do a little inner structure work.
    It's finally starting to look like something.
    Clark
    kidcampbell71 likes this.
  7. KustomCars
    KustomCars
    from Minnesota
  8. superchargednailhead
    Looks cool. Put that bitchin quickchange you have in that thing.
  9. Wow really nice work man....love your thought process and how you're going about it.
    Rat
  10. Clark
    Clark
    superchargednailhead....it's in there!! There's some other cool stuff coming. The intake I have for the Y block is cool...2x2
    Clark
  11. superchargednailhead
    Wow cool I want to see a pic of it. I can't wait to see that thing done. I'm getting itchy to start another one. Check out the tranny I put pictures of in another post you'll appreciate it. Did you see the pictures I sent Towers?
  12. Stovebolt
    Stovebolt
  13. Limey Kid
    Limey Kid
    Just bloody amazin! Great work Clark.
  14. Clark
    Clark
    Did some hammer and dolly work on the door top today....came out real nice.
    Also got the inner part almost done. Just need to add the flange at the door edge. Looks like I might be able to use my 33 door latches after all. Will try them tomorrow.
  15. Redz Rodz
    Redz Rodz
    7 day work week !! shootin' for the sand ? the body is lookin' real trick ! what trick do you have up your sleeve for the radiator ? did you see the pic's of the planned track ?
  16. Clark
    Clark
    Redz...just shooting for ASAP. I keep putting the radiator off hoping it will fix itself.. :) Don't think it will be too much of a problem. I can move the grill forward and inch or two if I have to.
    I do want to run it on the sand if possible!
    Clark
  17. 39 sledge
    39 sledge
    from p.a.
    i stopped in a few weeks ago clarks kicking ass,go man go see you tuesday morning.sledge.;)
  18. El Caballo
    El Caballo
    The number of the Prince of Heck?
    Yes I know...
  19. Clark
    Clark
    Well one thing led to another today. I bolted wheels on the car today. Sat it down and stared at it for a while. Well when I cut 4 inches off the hoodsides for the 37 grill...things got real tight for a radiator. I added 2 inches back to the hoodsides to see what it would look like. I liked the length of the hood but the frame horns looked wrong. Well off came the frame horns.
    After the frame horns were gone, Miles (VONBIRCH) was brainstrming the headlight mounts with me. I wanted a removeable mount and here's what we came up with. The headlight bar is mounted into a peice of DOM and will slide right out. The bar flows nicely with the grill and axle. It's all just tacked together and the drivers side does not have the headlight socket.
    Also got my wheels figured ut for the rear..well sorta. I've got a pair of Plymouth artillery wheels that I will make into 17 inch Goodyears. First I gotta get them widened for the 750/17 Goodyear tires. Then I have to cut apart a pair of Goodyear wheels..the center is two pieces. the outer just holds the hubcap.
  20. D ROD
    D ROD
    from New Jersey
    I got wood Clark, love the mock-up!!!
  21. TexasSpeed
    TexasSpeed
    I hadn't seen this thread until just now.. Dang!! I'm digging this.
  22. Clark
    Clark
    Thanks!!!
    Skidmarks...I'm gonna pull the intake that's on it so when Bill shows up with the one you fixed it can go right on!!
    Clark
  23. toddwith2ds
    toddwith2ds
    from AZ
    you are a reason that I bought an AD chevy truck, love your work and have subscribed!!!
  24. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Great Job!!!!!!!!!!!!!
    DRod, Got Wood II!
    Clark, What are you going to do for blister panels?
    I look forward to these posts!
  25. woodbutcher
    woodbutcher
    :D:eek:Geeze.Are you guys sure that this guys last name is`nt"Kent"?Because he is a "super man"when it comes to his fabrication skills.
    Great build.
    Good luck.Have fun.Be safe.
    Leo
  26. Clark
    Clark
    Thanks again everybody!!
    Kevin...I guess I'm gonna have to make them. I love the look of the stock ones....but with the 37 grill, pinched nose and channel, I doubt they will fit :)
    Woodbutcher...it's a good thing I don't run around in tights and a cape :)
    Clark
  27. redstraw
    redstraw
    from tn
    great build you make it look so easy.
  28. Looks great Clark! I like the way you spend time getting the proportions right.
  29. gnichols
    gnichols
    from Tampa, FL
    The styling on the front end is great, very pleasing with the axle / headlight bar like you said. I especially like the way the shape of the grille shell (narrower at the bottom) mimics the shape of the lower body and cowl - unlike Model T/A/B shells and their respective bodies. That's been "on my list" for some time and I'll put your photo at the top of my nifty ideas folder. Gary
  30. rcnut223
    rcnut223
    from wisconsin
    Really Nice Work!!!
