Projects My 29 roadster redo. From Rat to Track!
Discussion in 'Traditional Hot Rods' started by Pat, Jun 4, 2016.
  1. Pat
    Pat
    New Shortblock is a .080 over 261. Bowl ported 848 head with custom 2.02 intakes and 1.50 exhausts 78 cc' s chambers. 7.00" gmc 302 rods. Dema Elgin cam .472 lift 232deg at .050 solid lifters. Around 9.2 to 1 compression. After reading the flow bench tests on Inliners I'm going to remove the bulge in the combustion chamber by the exhaust valve. Should give me some more pep than my 235 and still be pump gas friendly!
    Gofannon likes this.
  2. Pat
    Pat
    image.jpeg Better side shot.
  3. Six Ball
    Six Ball
    from Nevada
    Munch, Munch flatheads for lunch. That is going to be a kick to drive in that little car. At a little over 272 inches it'll be a had full. The tired old GMC 270 in my pickup is still fun to drive.
  4. Looks great Pat, neat and complimentary to the whole package.
    Appreciate making the effort for my request, thanks.
    Cheers,
    Drewfus
  5. inliner2318
    inliner2318
    Talented!!! Great work and choice of power-train. Very jealous...:cool:
  6. Pat
    Pat
    I got to race at Trog Pismo. I had a blast!! Even with the rain and racing cut short. I had a smile all weekend. I got my new engine in and broke in the cam the week before the race, then took my wife for a roadster ride in the foothills to break in the motor a little. Noticeably stronger than the 235. I convinced myself that I should leave the Q.C gears at a 3.30 final ratio. Flipped I would have 4.10. I barely shifted to third at about 600 feet. Probably should have flipped gears! I took some good natured ribbing about my late model 54 engine. I need to build a 40's 270 jimmy to even things out! My wife got a cell phone movie of my race against Sushi and his T-v8. image.jpeg
    kiwijeff, Blues4U, Stogy and 4 others like this.
  7. Tim
    Tim
    from Raytown Mo
    Had fun painting one of your beach scenes :)
  8. tfeverfred
    tfeverfred
    Bad ass personified.
  9. Pat
    Pat
    Tim likes this.
  10. Six Ball
    Six Ball
    from Nevada
    Nice car, video and painting. Great thread. I like it even more than the Paso version. If you decide to build a 270 let me know. I might be able to help.
  11. Pat
    Pat
    Thanks! I had a early 270 to build up but didn't pass a mag test. Cracked #1 cylinder at the front of the block. So I went with a 261 I saved from a 51 pickup I own. I did use the Jimmy rods though.
  12. hasty
    hasty
    What a stunning car! And again, inspiring workmanship - thanks for all the detailed shots.
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Man, you did a beautiful job. Congrats!
  14. banjorear
    banjorear
    The work done to your car is gorgeous. Congrats.
    I've been meaning to start a thread about and maybe this isn't the time or place, but I'm curious how you finish the metal to look new after being shaped? Is it just a done of filing and sanding? I would love to learn how to work metal like this.
  15. belair
    belair
    How did I miss this. Stunner. And I really dig the 261. Looking for one to put in my 55 2 door sedan. And I love the Chevy tail lights turned 90 degrees.
  16. Pat
    Pat
    Yes. Filing and sanding. Lots of it! I mostly finish to about 400 grit wet sanding. Paper tends to load up on aluminum but red scotch Brite is about 320 grit and works well.
  17. x77matt
    x77matt
    Pat- thanks for this thread- totally bitchen' car and awesome metal work! You have great vision!
    Matt
  18. PINEAPPLE
    PINEAPPLE
    I found this thread today at lunch while researching what aluminum to use for making hot rod bits. I'm so happy to see this! Your wagon and Sellers coupe blew me away in that old rodders journal. Then that issue with this car hit, and I was floored once again. So glad you still have it and are making it even more refined. So inspirational. Congrats on all your hard work.
    Jimmy B and kidcampbell71 like this.
  19. Pat
    Pat
    Thank you! Not much to add yet. I will be dissembling for paint soon so I'll post pictures.
    Drewfus, bct, Jimmy B and 3 others like this.
