Projects My 29 A modified
Discussion in 'The Hokey Ass Message Board' started by bobo1, Sep 25, 2011.
  1. OahuEli
    OahuEli
    from Hawaii
    Search out one of the moderators. The only one I know of has the username metalshapes, and he can help you. Just let us know if we have to switch to a separate thread, we want to follow your progress. Eli
  2. bobo1
    bobo1
    from France
    Thank's Eli ;) I'm going to see what I can doing
  3. bobo1
    bobo1
    from France
    Some news , now I making the X menber with the pedal mount of 40 Ford ;)
    Then weld of X on the frame :)
    Now I can making the rear of the frame :D
    volvobrynk likes this.
  4. stephane-rod
    stephane-rod
    from france
    :eek: il en manque :D
    all right :p
  5. bobo1
    bobo1
    from France
    Some news of the project Organized of 4 bar links , then manufacturing of a false frame to determine the position of the spring
    With Hemi 392 I feign the weight I cut the back parts organized by the back crossbar then I weld the whole :D
  6. That's some nice engineering sir !! JW
  7. bobo1
    bobo1
    from France
    thank's ;)
  8. bobo1
    bobo1
    from France
    some news Now I'm finish the rear :)
  9. bobo1
    bobo1
    from France
    I have to make reinforcements for the front cross member
    And I have to make the mount of shock absorbers before 35 spring perches and I use orriginal ford 46 shock absorbers for the front and Ford trucks for the rear ;)
  10. bobo1
    bobo1
    from France
    doday fist mock up :)
  11. 2racer
    2racer
    car looks great, the wig not so much!
  12. bobo1
    bobo1
    from France
    The Modified is on the road :D and I'm making the front panar rod with tie rod of Ford Vedette ( Ford vedette is a small French Merc :D ) IMG_0009.JPG
  13. bobo1
    bobo1
    from France
  14. JakeDW
    JakeDW
    from Missouri
    Nice build.
    Jake
  15. bobo1
    bobo1
    from France
    Thank's Jake ;)
  16. bobo1
    bobo1
    from France
  17. bobo1
    bobo1
    from France
    Now I'm making the rear panar rod and finish the rear absorbeur shock IMG_0060.JPG
  18. bobo1
    bobo1
    from France
    I must put al :eek:
    in :D
  19. bobo1
    bobo1
    from France
    now I'm making the tank mount it's an orriginal Forson thank :) IMG_0193.JPG
  20. Vey tidy work, I like your attention to detail. Very cool. JW
  21. bobo1
    bobo1
    from France
    Thank's JW ;)
  22. bobo1
    bobo1
    from France
    Some news I finish the rear of tank mounts and I making the Headlight mounts . Headlight are Ford 35 IMG_0227.JPG
  23. bobo1
    bobo1
    from France
    I have to adapt master(teacher) roll on the crankset of ford 42 IMG_0255.JPG
  24. bobo1
    bobo1
    from France
    And my friend make the belts of the reservoir in stainless steel :) IMG_0273.JPG
  25. stephane-rod
    stephane-rod
    from france
    That modified is cool ;-) great job BoBo
  26. gnichols
    gnichols
    from Tampa, FL
    WoW. The back end is going to look fantastic. Gary
  27. my47buicksuper
    my47buicksuper
    from sunny fl.
  28. bobo1
    bobo1
    from France
    many thank's :)
  29. tiredford
    tiredford
    from Mo.
    When I see a coupster, what seperates the men from the boys is the windscreen. I have never seen one with the coupe windscreen frame that looked good. You have to cut that all off and start over. There are a lot of options on windscreens, even original style can be adapted. Also the capped original width doors need to be thinned down. These are items that can be spotted all the way across the parking lot that just scream COUPSTER.
  30. bobo1
    bobo1
    from France
    My English being very bad I am going to try to answer you d after the fact that I understood doors and windscreens were thinned look at photos
