Projects My '26 Roadster / Vintage photo search
Discussion in 'The Hokey Ass Message Board' started by MrModelT, Nov 12, 2008.
  1. oh yeah....and congrats on your engagement!!!
  2. 41 Dave
    41 Dave
    Clayton, The "T" is looking "bad to the bone !". It will omly be better when I can see it at Bonneville. Looking forward to seeing your Roadster and the Speedster.
    Dave
  3. MrModelT
    MrModelT
    *UPDATE*
    More and more wiring....
    Made some more good progress. Got the fuel pump mounted, the under hood wire loom made up and the ignition system/fuel pump wired up.
    Hidden under the hood shelves..
    The old style Cross-Courtney connectors wouldn't fit the newer terminals, so I had to use modern crimp-style connections. To dress them and give them the vintage look...I wrapped them in the cord and doped them..
    By the end of the day...we had a working electrical system...
    Chris also got the wire wheels painted...
    He did great work :D
    Stay tuned!
  4. Crazybillybob
    Crazybillybob
    from Ohio
    Clayton,
    You noted that you dopped the cord you wrapped around the modren connectors. What did you use epoxy, shallac, super glue?
    She's Looking real good it will not be long now till your back on the road.
    CBB
  5. MrModelT
    MrModelT
    Thanks Rusty! :D
    A Model A chassis is a useable option and good, strong platform to build on. I stuck with the T chassis because I had one and for me...it was personal preference. T frames and drivetrain components are plenty strong and easy to come by...plus, that little T engine is what makes a T a "T" in my opinion :)
    Thanks for the support as always Dave. You have always offered great compliments and support since day one....Chris and I appreciate every bit of it.
    I just used Testor's Glosscote Lacquer..simple hobby coating lacquer. You should be able to find it at your local hobby shop. Good old fashioned aircraft "dope" also works...and most likely would have been used in the old days.
  6. 41 Dave
    41 Dave
    Clayton, Thanks for the comment.
    I have been failing miserably elsewhere . . . . . Make me wonder some time . . . .
    Dave
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    Love the cord wrapped wiring terminals. The little details are what make this car what it is!
  8. Bigcheese327
    Bigcheese327
    Indeed, and what's really impressive is that he's trying to make a deadline. How many of us would just be putting things together as fast as possible, promising ourselves that we'd re-do it "right" later on?
  9. MrModelT
    MrModelT
    Thanks! I thought it would be a nice touch...and nice way to cover up those ugly crimp-on connectors.
    That is EXACTLY why. The first go around, this car was built on that "Let's rush it together ASAP...but I'll re-do it right later"...and it showed.
    This time around, I swore that I would "Do it right, or not at all"...and I have maintained that. I don't want to do this Chassis again..as I have other projects to move on to :D
  10. Kume
    Kume
    I am constantly distracted by that alternator :(
  11. Bigcheese327
    Bigcheese327
    Clayton hasn't noticed yet, but Henry and his friend Tom Edison stand over his bed at night and glare at him for defiling Lizzie with alternating current.
  12. MrModelT
    MrModelT
    ...A sacrifice I was willing to make for the sake of a WORKING charging system this time around. I want this "new" car to be self-sustaining (save for fuel of course).
    Eventually it will get a cover to make it look like a generator.
    ...and Dave, your comment made me laugh out loud :D
  13. MrModelT
    MrModelT
    I have grown tired of having to charge the battery before every-other trip. The original generator just didn't have the output for a 12v coil ignition system.
    Don't worry...I'll hide it and make it "work" :D
  14. I bet Tesla's standing on the other side, thumbing his nose at Edison :D
    Outback likes this.
  15. sinticket
    sinticket
    This is one of my favorite cars on the HAMB! Awesome car my friend!
  16. MrModelT
    MrModelT
    ...you guys crack me up :D
    Thanks Sinticket! Hopefully it will be a FUNCTIONING car soon! :rolleyes:
  17. Light it off!
    Light it off!
  18. gnichols
    gnichols
    from Tampa, FL
    Doesn't someone make a fake alternator that looks like an oh-so-correct yet worthless generator? Gary
  19. Bigcheese327
    Bigcheese327
    Powermaster makes a faux-generator alternator that fits the bill, but it's styled after later generators and is intended to be belt driven. I think (and I know Clayton will correct me if I'm wrong) Model T generators are gear-driven, though, so it wouldn't be a direct replacement.
    Too bad T generators are so crummy. The generator on my Falcon has given me good service thus far.
  20. MrModelT
    MrModelT
    I believe there are a few companies that are making "Genernators", but they don't make such a product for a T...that I know of. I could run a belt drive setup with a "genernator" built for a Model A perhaps...but I do like the direct gear drive setup.
    You are also correct about the Model T generators Dave. The Model T generators do work, they just don't have enough output for a system like this. They are a "trickle charge" unit that was designed to keep the battery up while the motor was running off the mag.
  21. 41 Dave
    41 Dave
    Clayton, Looking like you are still making some good progress on you "T". Would like to be there when you light the fuse to that Mill ! Bet your smile might be a new record for Ripley's ! Will stay tuned as you make further progress.
    Dave
  22. There are some mini alternators that will just about slip into a generator :)
  23. MrModelT
    MrModelT
    True, but I just don't have the time now before Bonneville to design and machine up a custom mini in a T generator case unfortunately.
    ...I will put this on the "to do" list for after Bonneville :D
  24. Crazybillybob
    Crazybillybob
    from Ohio
    One thing to watch when "hiding" the alternator is heat. Simply covering in sheetmetal may look good but it will not last long. The coils in the alternator get toasty when doing it's job good airflow is the only thing that cools those coils. Some of the early gear driven alternators sold had this issue because the adapters covered some of the intake ports on the front of the units.
  25. GARY?
    GARY?
    Things will be looking salty pretty soon. :D
    Great progress. One of the sweetest Ts just keeps getting sweeter.
    I barely notice the alternator in there. It's so dang practical, I wouldn't sweat it at all.
  26. MrModelT
    MrModelT
    Agreed :D Its just getting to that point is taking a bit longer then I had hoped...or intended. Still waiting on as few parts to complete the fuel system and plumb the carbs.
    This is something I was worried about myself. If I do go that route...I would do my best to keep it cool. The cover would most likely be punched for air ventilation.
    ..either way, a cover for that thing is the LEAST of my worries right now.
    Thanks Gary! :D I'm not out of the woods yet, but I know I will be adding some "salt" soon...:rolleyes:
  27. Crazybillybob
    Crazybillybob
    from Ohio
    Please tell me your going to add NOS to it :eek: you are going to the salt with her.
    At this point if you can live with it....others may grumble but the will except it in the end.
    Nos= nitrousoxide
  28. MrModelT
    MrModelT
    No, no NOS :D....just driving it to Bonneville this year for speed week. I'm not going to race it, just gonna spectate.
    ..that is what this whole rebuild was for and why I'm rushing to get it done.
  29. MrModelT
    MrModelT
    *UPDATE*
    Electrical ALMOST done!
    Well, the electrical system is almost done. The Starter is in and the tail light is rebuilt, connected up and working...
    Added a stoplight switch this time around so that the tail light works as it is supposed to...
    With running lights on...
    and brakes on...
    more to come!
  30. What's all that plastic stuff on them wires :)???
