Projects My 1950 Buick Sedanette rebuild officially kicks off!
Discussion in 'The Hokey Ass Message Board' started by 1950_Buick, Jun 13, 2014.
  1. 1950_Buick
    1950_Buick
    Thanks! That's my thinking exactly as I want this as my daily and therefore want the driveline/suspension updated.
  2. Wow. How much power do you think that will put out?
  3. 1950_Buick
    1950_Buick
    hmmmm, tough to say at this point, however I plan to eventually run this at 30 psi on the twin turbo setup... hence the beefy trans to handle the power.
    LONG likes this.
  4. 1950_Buick
    1950_Buick
    Ford 9" is in with 4-link, custom driveshaft hoop has been added that'll work with the airbag system, and first part of the frame is boxed now to start on the front end.
  5. 1950_Buick
    1950_Buick
    some more work in progress shots...
  6. 1950_Buick
    1950_Buick
    Not a whole lot new but wasn't happy with the plates with the 4-link so reworked it to something more durable....
    Still have to shorten the 9"
    LONG likes this.
  7. Blase
    Blase
    Looking good! Couple of questions. Is this going to be a four link with a track bar? How long are those links? They look kind of short.
  8. 1950_Buick
    1950_Buick
  9. 1950_Buick
    1950_Buick
    doing some more work with the frame flipped over...
    LONG and Blase like this.
  10. 1950_Buick
    1950_Buick
    some more pics...
    11137147_1004633346253805_5804544989646678413_n.jpg 11144964_1004633322920474_1147835902256844432_n.jpg 11215513_1004633189587154_7292865659278891501_n.jpg 11951773_1004633259587147_1800214689058764467_n.jpg 11987079_1004633139587159_6445636897146264105_n.jpg 11998855_1004633279587145_7233771675201297035_n.jpg 11998969_1004633242920482_9064685851163905762_n.jpg
    LONG and ausbuick like this.
  11. 1950_Buick
    1950_Buick
    getting a start on the front end...
    ausbuick likes this.
  12. 1950_Buick
    1950_Buick
    The front end is starting to come together. Installing the JW Rod Garage Mustang II IFS....
    ausbuick and LONG like this.
  13. 1950_Buick
    1950_Buick
    more progress on the front end...
    LONG likes this.
  14. wicarnut
    wicarnut
    Kool car ! Nice work ! Where did you get disc brake conversion for original spindles early in this post ? Have a 51 Roadmaster. Thanks !
  15. 1950_Buick
    1950_Buick
    This is a "Scarebird" kit that I picked up off of ebay (http://www.ebay.com/itm/Buick-Speci...ake-/390273013377?hash=item5ade159681&vxp=mtr)
    What you see is what you get in the picture off of ebay. He also gives you the part numbers for the rotors, calipers and pads that fit this so you can go to your local parts store and buy them. I think in addition to the $225 for the kit, the rotors will run you approx $80, Calipers hmmm I think $140 and pads $40.
    If you are interested, I put less than 500 miles on mine before I started working on my car and was going to throw the whole setup up for sale - let me know if interested.
    LONG and wicarnut like this.
  16. Blase
    Blase
    Who's front end did you use? Also what all came with the kit? I noticed the two main rails were not welded together so I was thinking (mistake I tell ya) that maybe you provided those?
  17. 1950_Buick
    1950_Buick
    JW Rod Garage
    Here's the catalogue page with what comes with their kit: (1939-51 GM, B, P, O)
    http://www.jwrodgarage.com/catalog-of-items/specialty-ifs-kits/
    I modified the above kit with their "air bag kit components" from page 1 but didn't take their bags, cheaper quality than what I wanted and so I bought Slam Specialties Bags instead, I also upgraded to their new power steering rack for an extra $100: (page 1 of JW Rod catalogue)
    http://www.jwrodgarage.com/catalog-of-items/mii-hub-to-hub-kits/
    As for the rails not welded together, that's intentional on their part so you can adjust the width for your application.
    As you can see from the pics, their stuff is great quality - I would highly recommend JW Rod Garage, great guys to deal with as well.
  18. 1950_Buick
    1950_Buick
    LONG likes this.
  19. 1950_Buick
    1950_Buick
    Body temporarily back on the frame for final measurements/mock ups...
  20. 1950_Buick
    1950_Buick
    Looks like the 5 gallon air tanks will fit nicely under the body ... one on each side...
    LONG likes this.
  21. 1950_Buick
    1950_Buick
    Engine and Trans checking out their new home....
  22. 1950_Buick
    1950_Buick
    looking up...
  23. 1950_Buick
    1950_Buick
    Bags in, shock mounts in place...
    LONG likes this.
  24. 1950_Buick
    1950_Buick
    A couple of shots from the back... air tanks in place, had to cut and sleeve the hoop for proper clearance...
    also have to replace the truck oil pan for a lower clearance one
    12011179_1016758571707949_5318163401881740739_n.jpg 12002187_1016758738374599_8716796263895730012_n.jpg
    LONG likes this.
  25. 1950_Buick
    1950_Buick
    3 1/2 inches need to be cut from the left side of the 9"
  26. 1950_Buick
    1950_Buick
    work has been on a bit of a hiatus lately, but here's a couple more pics...
    12106941_1025149414202198_2556961202249686973_n.jpg 12068805_1025149174202222_4827003064567038085_o.jpg 12066047_1025148934202246_712996017278661547_n.jpg 11201811_1025148680868938_2415362634930098212_n.jpg
  27. 1950_Buick
    1950_Buick
    Temporarily moving locations with some oddball wheels, however liking the lowered look - this is the bags at their highest clearance... this thing is going to sit nice and low!
    12115605_1025929134124226_3097862367412664497_n.jpg 12106990_1025929097457563_3658559631875025140_n.jpg
    LONG likes this.
  28. 1950_Buick
    1950_Buick
    I just ended up buying this tonight... shipping to me tomorrow
    9 inch N case strange pinion support and yoke. Mark Williams 35 spline spool with richmond 28 spline 3.70 gear.
    (Racepac sensor not included.)
  29. Fat47
    Fat47
    I used the JW Garage M-II conversion on my 49 Sedanette build. Same as you did. But, I had to modify the front frame rails substantially in order to bolt the stock bumper to the rails. Ended up pie cutting them in front of the A-arms and angling them down towards the ground quite a bit. Have you tried to mock up your front bumper yet?
  30. 1950_Buick
    1950_Buick
    no i haven't yet...
    i am sending the rear end out to currie to shorten the left side, seeing they already have a jig to do this and I'll get some axles from them. Then I wanted to put the radiator and intercooler in first, to see how much room I had and then the plan was to use the old front clip and weld that into the MII.
    Thanks for the heads up as I wasn't anticipating any issues... I'll let you know how I get on.
    cheers!
