Got her home. Just wondering where I should start from here ? Put the wiring in and dash then steering column all the lights, chrome, bumpers, exhaust, Then the glass and interior ? Lots to do just wondering if there is a good order to go or just start putting everything I have on ? Sent from my iPhone using The H.A.M.B. mobile app
I'd probably start with the steering column and wiring and anything else need to make it movable under its own power. Than do the exhaust to keep the neighbors happy. Save the chrome for last. Looking real good. Going to be a very nice car when your finished.
Got my bumpers kinda figured out bolts spun wrinkled and flaked some chrome off. Got my tail lights and grill put in. Steering column kinda in, need to get it to shift right can't get the upper arm to move. Sent from my iPhone using The H.A.M.B. mobile app
Ordered up a firewall insulator from Quiteride should be here in a couple weeks. They make it after you order it. Question is what clips do I use to put it on with? Sent from my iPhone using H.A.M.B.
First time putting coolant in my Flathead & heater core. Just got it hooked up yesterday. Should I just run water and flush it out or put a 50/50 green coolant mix & see how it goes?Thanks for the help. Sent from my iPhone using The H.A.M.B. mobile app
Do the wiring while it's blown apart. Add accessories as you go=lights/switches/do dad's.... Cut to fit AFTER wiring seem's a mile to long, and pieces are in. LQQKIN GOOD!
Run water to make sure their are no leaks. Looking really good. Sent from my SM-G930P using The H.A.M.B. mobile app
Yeah I think I will run water first see if any leaks then go with 50/50 green coolant. My next plans are fill with coolant see if any leaks. Get fuel line ran maybe put in a inline fuel pump. Get exhaust ran, steering linkage working then do some wiring and dash put in. Sent from my iPhone using H.A.M.B.
Are you doing your exhaust yourself from scratch? Sent from my SM-G930P using The H.A.M.B. mobile app
For thought= If you run straight h20- and you have a leak- how big do you think the leak will be? = a hose clamp,a loose fitting, etc..... and the million $ Q? if you have straight h20, are you going to be able/have the means to get it ALL out, and start fresh=zero? How much will be trapped in the block?..... Sacrifice coolant, find any unforeseen leeks, and be done.
I think I’m going to put in 50/50 and see how it goes. Just try and make sure everything is correct before I do. Looks like my temperature sending units might be on the wrong side and make sure my heater core hoses are correct. Sent from my iPhone using H.A.M.B.
Thank you, chrome looks nice, now I need to start adding some color to the car. Sent from my iPhone using The H.A.M.B. mobile app
I just got some distilled water green concentrate antifreeze and water wetter. Going to get gauges after I see if there are any leaks. Need to get a 4lb Rad Cap also. Sent from my iPhone using H.A.M.B.
So not to bad only had one leak. The left side water neck has a crack in it. Let it run for a 1/2 hr. Small oil leak out the bottom of the dipstick. Sent from my iPhone using H.A.M.B.
Got the motor running good new 180 T stats. Got the seats down and took 2 layers of seat covers off put the seats in and got some blankets from Cabo on our vacation. Put the mirrors on steering column in, just doesn’t shift quite right 2nd & 3rd shift good 1st & reverse are hard because of the column. Put the dash in a couple times. Pulled the wiper motor apart cleaned it up & got a couple new parts and put it in, stayed with the vacuum. Best part is i drove out of the shop under its own power for the first time in 16 years. Getting ready to get exhaust this week then glass put in. Sent from my iPhone using The H.A.M.B. mobile app
Nice build, coming right along. Who did you use for the chrome plating? Thanks for the well documented build thread.
I used Bumper Depot for my bumpers everything else I have just washed up and maybe get it redone later on down the road. Trying just to get it to be a cool driver for now. Sent from my iPhone using The H.A.M.B. mobile app
Getting exhaust put on this weekend. Reds headers & porter mufflers 1.75 out the back. Sent from my iPhone using The H.A.M.B. mobile app
Great job your doing , will be watching for the conclusion over the next while . Let's hear it when you get her home !
Took my car up to a buddies house to get exhaust, my shifter issues, breaks, Door stop & lower the rear 3” hopefully be able to drive it up and down the road when I get it back. Then I have a guy coming over to look at putting some glass in it. Sent from my iPhone using The H.A.M.B. mobile app
Lowered 3 more inches in the rear and got exhaust on today. Sent from my iPhone using The H.A.M.B. mobile app
