Projects My 1948 Pontiac Build (A little bit custom and a whole lot faster)
Discussion in 'The Hokey Ass Message Board' started by speters, Jul 20, 2011.
  1. scootermcrad
    scootermcrad
    Really cool build!
    I have to go ahead and agree with the others that are voting for keeping the trim. The thing that REALLY sets Pontiac apart from all the other makes of this era was the trim. The car can be done smooth without losing the trim and the STANCE you have planned will really make it.
    At least leave the waterfalls on the hood and deck lid. Just my $.02, but I'm a Poncho owner as well and we are lucky to have them... trim and all. There's not that many on the road.
  2. mgtstumpy
    mgtstumpy
    I have the same 'B' bodied 46 Olds. Keeping all the OEM chrome and trim and painting in it OEM 2 tone colours. Upholstering it with OEM trim and redoing the woodgraining on dash and garnish molds. Going with a 6x2 crossram SBC with T700 and OEM column shift and on bags to get it down low. An Olds engine would be nicer however they're not readilly available downunder, all we got were basic poverty pack models that were phased out in favour of locally made GM. Mopar and Ford products.
    This is a local Pontiac sedanette getting around that was left as found apart from fitting a 350/350 combo, airbags and a new metallic red vinyl interior.
  3. speters
    speters
    As of this morning
    Stripped out some more
    Rear seat bottom
    Rear seat back
    Front window moldings
    Hub caps and arm rests
    Found this piece of glass on the rear tray
    Driver door is in bad shape
    Looks like some moisture made its way into the back seat
    Before I was worried about modifying good metal in order to accomidate a notch and bags but since it is junk anyways I won't feel bad about it
  4. csimonds
    csimonds
    Wow man, it amazes me that the Pontiac is in that good of shape! I got my Buick in Manchester back in October and she almost road ready. Still working out a few kinks, but this weekend might be it lol.
    Chuck
  5. speters
    speters
    I am glad you think it is in good shape because after last night I was disappointed to see how bad the rear seat frame looked and how bad the rust is back there. I just need to get it all apart and blasted and I will feel much better
  6. Soreback
    Soreback
    Maybe a rotisserie is in order. I got a set of very complete / comprehensive plans for building one. I got them from Frozen Merc here on HAMB. He e-mailed the CAD plans to me no charge.
  7. speters
    speters
    I am thinking I will need to build a body dolly or rotisserie in order to blast this thing. I stilled have not talked to my blaster to see what he would want.
  8. csimonds
    csimonds
    Floors are easy to replace. Is the frame nice and solid? You can do it!
    Chuck
  9. speters
    speters
    The frame is looking good. It might have a small soft spot under the front driver floor pan but I think that is it.
  10. csimonds
    csimonds
    No worries Bro! I'm am posative that car is going to be BAD ASS!!!!
  11. mgtstumpy
    mgtstumpy
    Here's my body being sand blasted. Make sure you select someone that knows what they are doing as inexperience will ruin the panels by putting too much heat in an area. My blaster moved around and didn't concentrate the heat which avoided distorting the panels. Soda blasting is a different story and only needs to be neutralised afterwards.
    Once body was blasted I ran a heavy scothbrite disc over it to remove any traces of any ingrained surface rust before etch priming the entire body and all hang on panels. Once done, you can see exactly what needs to be done and where the problem areas are. I have enough steel left over to make a chassis jig to do front and rear suspension.
    This is the rotisserie I made, I can PM some specs if required. All you do is use the hydraulic rams to get the body / chassis to working height, saves crawling around underneath. I used a welder friend to get quality penetration welds and heavy gauge RHS. Theoretically I can easily lift a complete assembled car. I just need an engineer friend to calculate it's limitations. Do it once, do it right.;)
  12. ZZ-IRON
    ZZ-IRON
    from Minnesota
    cool find the outer body looks decent + the trim
    when it comes to sand blasting remember now you see it now you don't
    a lot of that seat area will be gone
    the floor forward looks like it will make
    take some measurements in the seat area
    easier to figure or make paper patterns
    photos help a lot when making new parts
    you have an idea what was there
  13. skoh73
    skoh73
    Wow, what a cool car- don't see many of those that's for sure! Can't wait for more progress pics.
    Even your basketball net looks period correct!
  14. speters
    speters
    Thanks for the sandblasting suggestions. I use a guy near me who mostly does automotive and is very good. He did the cab on our 54 project. If I went even more custom does anyone have ideas for a custom grill?
  15. Not a bad start at all. Soome years back I bougoht my 48 and was able to drive it home...straight 8 with the hydro...first year for the automatic.
    I wanted to keep all the trim on mine as that sets it apart from the other GM fastbacks in 48 and I just like it. I kept the straight 8 while building a dual quad 389 for it....never got the engine installed and it ended up in Diryt 2's 38 ford coupe...
    I drove the shit outta mine and aside from replacing a U-joint at the Leadsleds in Springfield, Ill, it never caused me any grief..
    I used 4 inch blocks in the back, cut coils in the front with short tires on sandblasted chrome reversed wheels. If you keep the rear axle, do yourself a favor and use a 55-56 Pontiac 3.23 ratio thrid member in the original 48 housing with original 48 axle shafts....makes it almost freeway driveable with the straight 8 and no problem with a modern V/8..
  16. Orn
    Orn
    Rocky, I like your 48 a lot. Nice ride :cool:
  17. speters
    speters
    Thanks for the info Rocky! I like the stance on your 48. Do you still have it? How was the ride quality with those modifications?
  18. speters
    speters
    Did a little work yesterday.
    The rear wheels were locked up which was making it hard to roll this thing around. I took off the drums and solved the problem.
    Then I moved on to the engine bay and took some more stuff out
    I also took some time to set up my latest garage toy
  19. shitbox2
    shitbox2
    heres mine bagged in the front for now
  20. csimonds
    csimonds
    Nice pic Shitbox2, to bad it is in front of a RAC, I worked at that shithole for 8 years here in CT.... But Damn you car in front makes it look so much better!
    Chuck
  21. sololobo
    sololobo
    Just my opinion, but removing hood or deck trim on these cars is a major step backward. You don't like that cool stuff, buy a Chevy. Your car, what ever. Good luck with the build of one of my fave cars ever. ~sololobo~
  22. speters
    speters
    I am leaning more and more towards keeping them
  23. speters
    speters
    Last night I got the new welder up and running after buying a tank and building an extension cord.
  24. speters
    speters
    My friend Aaron came over for another Wednesday night car session. Here are the results
    Front seat is out
    There was a heater under the driver seat that I didn't even know about. Pretty cool
    Here is the front drivers side floor rust
    Chief on the steering wheel
    Drivers view is still bad
    Door panels off with Aaron hiding
    Started taking off the trim
    A couple of the trim screws did not want to go
    Radiator out was well as some of the supports
    The pile in the attic is growing
    And now that the rear wheels are free we moved it inside. I am sure the neighbors appreciate that move
    Looking like it belongs
    Almost looks like it is smiling
  25. speters
    speters
    The work continues!
    Hood trim is gone
    Chrome collection
    Looks bad but I think it will still be fine
    I cleaned one up a bit just to see how bad it was
    Rear bumper off, rear apron off, trunk stripe gone, taillights off and the trunk is actually not attached and just sitting there
    Glove box off, the rest of the interior window trim is off, and the dash is next to go
    Molding gone
    Rear seat support is out
    These fender pieces are not as easy to get off as I thought
  26. speters
    speters
    I need some advice on bumpers
    I love the look of the 1 piece bumper on the back of Glen's old buick
    Does anyone know what car that is from? Glen has not answered my PMs about it.
    Should I leave my bumper 3 piece and just loose the spears on the ends? Should I cut and butt weld my bumpers to make them both 1 piece?
    Does anyone know some 1 piece bumpers that might fit?
  27. gassercrazy41
    gassercrazy41
    man oh man....i've always had a soft spot for 48's
  28. csimonds
    csimonds
    It still amazes me that your car is in such solid shape being a Northeast "rustbelt" car! Looks as though you are making quick work of the teardown.
    Chuck
  29. speters
    speters
    I can't wait to start getting pieces out to people. Once I have parts at chrome, powder and blast I will start to get crazy excited.
  30. speters
    speters
    I have seen a lot of 48 fleetlines with 1 piece bumpers like this
    Any idea where they are getting them?
