Projects My 1940 Ford project or how to ruin a perfectly good car
Discussion in 'Traditional Customs' started by the man, Nov 9, 2021.
  1. 40Standard
    40Standard
    from Indy
    change the wheels and drive the hell out of it
  2. Love her just the ways sits…minus the rear suspension and wheels. Absolutely dig that color!
  3. buick bill
    buick bill
    from yreka;ca
    lets see 40 ford - chopped 40 ford . sometimes its hard to deal with what life throws at us . you can change your mind a hundred times . till ya light the torch !! drive now /decide later . oh if no one said it . SCORE !!
  4. jim snow
    jim snow
    I’m with most. Fix what needs to be done to make it safe. Then drive it awhile before any drastic changes.jmho. Snowman
    pprather likes this.
  5. Stogy
    Stogy
    I'm all for taking a vehicle to another level but saying your ruining it sends fuel to the Custom Haters...
    Congrats on your new adventure...
    I look forward to you taking this 40 to a new level...Lower and Smoother...;)
    brady1929 likes this.
  6. PotvinV8
    PotvinV8
    A leaf spring setup in the rear with some lowering blocks, change the wheels and tires, and you'd be well on your way to achieving the tail dragger look you're after without cutting anything up. If you get sick of that look, remove the lowering blocks, give the car a little hot rod rake and you're back to a basic '40 hot rod without changing much of anything.
    Stogy likes this.
  7. Jessie J.
    Jessie J.
    The '40 Coupe is one of the cleanest, most classic designs Ford ever made.
    "Restyling" one is usually not viewed as an improvement.
  8. Some updates. I pulled and replaced all of the suspension. 2 link, IFS and air ride. A new set of Firestones replaced steering column and wheel. Started the upholstery. Still need to do my bench seat. Started stripping the old yellow paint.
    Crusty Chevy, rottenpop, winr and 8 others like this.
  9. Stogy
    Stogy
    The suspension removed will help another project and the modern upgrade will give you mood adjustments with the flick of a switch...
    The external work is fitting...looks good...coming together...
    chevyfordman likes this.
  10. Whoamel
    Whoamel
    from So Cal
    I have a '40 Coupe with leafs and lowered like yours was when you first got it. I don't plan on changing it as I really like it as is.
    BUT, yours looks really BADASS the way it is now. Nice job!
  11. dan griffin
    dan griffin
    In the early 50s if you had a tail dragging 40 you were a bad SOB.
  12. That looks to be a real nice body under the yellow paint.
  13. When in high school, I lowered my '40 all around with shackles about 8" long. That lasted about a day.
    Stogy likes this.
  14. Squablow
    Squablow
    I'd have been tempted to make a yellow taildragger based on that mockup pic with the (cardboard?) skirts on it. Do you have plans for a color?
    That old engineered rear suspension is both hilarious and terrifying. Looks like both wishbones were located with a single bolt to a piece of angle iron which itself was bolted to the frame? Whoever built that thing REALLY believed in the shear strength of a single bolt!
    Stogy likes this.
  15. 1-SHOT
    1-SHOT
    from Denton
    Was your car from the Dallas area? if it was I may know one of the original owners.
    Stogy likes this.
  16. Stogy
    Stogy
    Butt Alass...It is the Hamb after all...where design takes second place many times to the meaning of Hotrod Life winning the race and in Custom taking it to another level...
  17. Stogy
    Stogy
    Ahhh!!...it was you who started it!!!...any pics?
  18. No, got home from school and pulled them off. Car handled like a stage coach. Seemed like a cool idea at the time though.
    Stogy likes this.
  19. Stogy
    Stogy
    Probably the weight on the stilts doing the stress walk side to side...I guess having spring at both ends made that possible in theory...but here were other details at play for the Young Choffman...40 in high school how cool is that...sure beats the stuff we had to get around with...
  20. aussie57wag
    aussie57wag
    from australia
    That's a cool car. I'm not really a fan of sbc. But the 4 speed is cool. I love tail draggers but you need to go all old school. Flathead and column shift trans.
