Technical Mundane jobs when building a car
Discussion in 'The Hokey Ass Message Board' started by bill gruendeman, Jan 14, 2020.
  1. bill gruendeman
    bill gruendeman
    I was thinking the other day when I was blasting small parts in my blast cabinet, This is relaxing and kind of fun. What other jobs are mundane to most guys but you like to do.
  2. Uribe
    Uribe
  3. flamedabone
    flamedabone
    Defiantly my least favorite.
    -Abone.
  4. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Painting. Not the masking or block sanding part. But I will put a rattle can to work. I get in the zone
    Jalopy Joker and bill gruendeman like this.
  5. 302GMC
    302GMC
    from Idaho
    Trying to remember where I put stuff 10 minutes ago ….
  6. oldiron 440
    oldiron 440
    Then looking for it all day!
    rbrewer, LAROKE and bill gruendeman like this.
  7. southcross2631
    southcross2631
    Fabricating and welding in patch panels. I like making stuff . I had a 2014-09-11 12.13.49.jpg 2012-01-09 06.13.26.jpg lot of fun on this project.
    chop job, GordonC and bill gruendeman like this.
  8. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    worst- buying the replacement and finding it the next day, right out in the open.
  9. ramblin dan
    ramblin dan
    Going to a swap meet and buying something, bring it home, open a box to put it in and finding two more of the same things you already bought that day.
    bill gruendeman likes this.
  10. Almostdone
    Almostdone
    Making stuff I could have bought.
    FC3E22B5-26FD-4347-BD9C-C57ABF9BB3F6.jpeg 5040DCC9-A103-48E4-BBA5-D5B1515DE57D.jpeg 8E6ED091-37A3-4DA6-818A-F119BE673C6A.jpeg 703AA7A1-CDC5-4214-8080-DA6ABCAF7085.jpeg
    bill gruendeman and 62rebel like this.
  11. LAROKE
    LAROKE
    Deep Ponder Mode in my shop chair with a craft beer and a cigar.
    weps, Just Gary, scotty t and 5 others like this.
  12. indcontrols
    indcontrols
    ^^^^^ Yup, exactly what Laroke said
    bill gruendeman and LAROKE like this.
  13. Beanscoot
    Beanscoot
    Cleaning parts in solvent. Up to my elbows in gasoline.
  14. Mr48chev
    I've never minded the block sanding and long boarding to get a panel as perfect as I can for some odd reason. For me that is when I can see actual progress.
    When I first built the 48 in 1973 I did one panel at a time usually working about 4 hours a morning first sanding off about four coats of brush paint jobs and getting down to either bare metal of what was left of the factory paint and then working on a panel at a time priming, blocking and a bit of filling and more priming and blocking and sanding all while driving it to work every afternoon as I worked evenings in a Ryder truck shop at the time. I was on a quest to have it as close to perfect as I could get it and pretty near met that quest.
  15. RMONTY
    RMONTY
    Were you ever 100% satisfied? I never am. I just say "I'm the only one it makes any difference to anyway!"
  16. Chappy444
    Chappy444
    1. Maryland HAMBers
    Cleaning away years of grime and crud... I prefer to get dirty once and then be able to work with "clean" parts. I hate getting dirty every time I work on the car if I dont have to.
    I also like to wire wheel small parts and get them painted or polished.
    Chappy
  17. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Yup, this is it for me, too. Up to your armpits in dirt, tracking it all over and THEN spending TWICE as long cleaning up the mess. Probably should just buy one of those dustless blasting setups and blast anything that comes within a 100 yards of the property....
  18. jnaki
    jnaki
    Hello,
    I was the daily maintenance kid for my brother’s first cars. I could drive both of them in those years, but not legally. He gave me the jobs that he did not want to do and at first, I was a happy kid doing something to his hot rods/cruisers. For me, it was exciting as being part of a daily routine of doing something on a real car. Plus, when finished spray washing the Impala, I had to clean out those drip weeping holes under the door and body panels. The best way was with a hole punch and drive the Impala around the block. “Hey, mom, I am just going around the block to drain out some water from the Impala…”
    upload_2020-2-24_5-14-30.png Early approved driving techniques...
    Now, when my brother got the Impala dirty from a road trip to the desert or local mountains, then the cleaning called for driving the Impala a few more blocks to the power spray wash machine location. The more driving I was able to do, made the mundane job of washing a car more rewarding.
    58 impala out for a "dry" run to rewards
    My brother showed me how to do a lot of the daily or weekly items that were fairly simple. I was the expert wax, the car wash and detail guy. I could change the wheels and tires in a snap and do the basic bolting and unbolting of various attachments, etc. (side pipes, header bolts, etc.) My only mistake was to drill great looking holes in the Oldsmobile sedan rims. Then attaching the Moon disc with screws. The only ones I could find were some that were in our garage drawer. But, they were not the ones that came with the Moon Disc Kit, I found out later.
    The reason I found out was his car was sitting in the driveway lowered more than normal. I had used sheet metal screws instead of the flat end screws. The sheet metal screws went right through the rubber bead and caused a small leak. But, hey, I was not even a teenager, yet and made my first mistake. Luckily, my brother yelled at first, but gave me a bag of flat end screws that he had in his jacket. (his mistake, too.) I changed all of them and put in flat tire repair glue in the holes. That did enough to get us to the gas station for some new inner tubes for the tires. Lesson learned…
    Jnaki
    So, the mundane jobs that I learned as a little kid was based on several things: 1. My brother knew he had a slave to do some work so I could get rides to various places instead of taking the bus. 2. He like hot rods and vehicles of any kind, but would allow me to do the daily routine or simple stuff that he did not want to do to his cars. 3. He taught me well for the skills I needed to complete the jobs. 4. Then it became a routine that had to be done, but was getting to be a bit much. I realized that those tasks were necessary part of any build or maintenance for all hot rods or cruisers.
    When we were building our two versions of the 1940 Willys Coupe for the B/Gas and C/Gas classes, nothing was mundane. Everything was exciting, seeing what we could do and did finish. It was coming together slowly, but we were learning and wanted to do a good job in what repairs or additions were needed to make the Willys Coupe run well. This part had no daily simple stuff as it was something new every day or week. We were creating a hot rod for the dual use of street driving and mostly drag racing at Lions Dragstrip.
    upload_2020-2-24_5-11-51.png similar 671 motor, carbs and drive… B. Balogh
    In the years and cars that followed, it wasn’t necessarily the dread of doing those simple things, but a job(s) that they were always sitting in the garage waiting for some completion. Once completed, then it starts all over again.
    charleyw likes this.
  19. Baumi
    Baumi
    Cutting out out bad old repairs or rusty panels and welding in new steel , that´s it for me... but cleaning and assembling a perfectly machined engine , that´s pretty relaxing to me aswell.
  20. 57JoeFoMoPar
    57JoeFoMoPar
    For me it's always the incidental stuff. It's so easy to forget that doing something like an engine swap is so much more than physically mounting the engine in the car. All of the plumbing, wiring, linkages, etc., that make the engine actually work, are what the the most time.
    The only saving grace about those parts of the job are that there are so many tasks to perform, but they're comparatively small, that you tend to move through them quickly and give the impression of big progress.
  21. I used to enjoy the hunt for hard to find parts or better prices on new parts. Now I guess I like sitting in the garage listening to good music, sometimes drinking cheap beer or more often iced tea thinking about what needs to be done( but not doing it)
  22. Bandit Billy
    Bandit Billy
    Over the weekend I faced one of the task I dread the most, duplicating my own work. A couple of weeks ago I modified my running boards on the 41 ford truck and sunk a header dump/lake pipe into the left side. I have been putting it off but I cant got the exhaust shop with one pipe so I spent most of the day yesterday trying to knock off my own work in mirror image for the right side board. It is not as much fun as the first side, just tedious measuring, cutting, welding, drilling, grinding...oh the humanity!
  23. RJP
    RJP
    from PNW
    Drilling and chamfering lightening holes using a drill press. I pull up a stool, and get to drilling. I'll even use different size bits and intricate patterns just to make it last longer.
  24. Gman0046
    Gman0046
    Rust repair sucks.
    Bandit Billy and bill gruendeman like this.
  25. And yet you do fantastic work, and the paint the cars BLACK! HRP
