I'm doing some clean-up under the hood of my '37 and I had a quick question on the MSD Ignition that is in it. The car currently has two coils. Is there any real need for this? Looking at the installation instructions on-line it doesn't show a two coil application. The coils are wired separately out of the module. The installation instructions don't show that either. If I ditch a coil, is the harness for the coils coming out of the unit a plug? I didn't look at it that closely. Thanks in advance. Allan
I've never seen that before! You'd want to get all the wires out to where you can see them, and figure out where they all go. If you do that, let us know, maybe we can help you figure it out.
Well that was interesting. The dual coil leads were just spliced into the end of MSD harness. I guess a new coil is on the shopping list. Anyone want a coil set up ready for the Zombie Apocalypse? Allan
I ran an MSD 6A for years with a Blaster 2 coil, it worked fine. I don't know if it's the best thing for you, or not.
Our biggest and baddest coil for the 6AL is our Blaster HVC coil, PN 8253 MSD Admin MSD Tech Support 915-855-7123
Curious about the two coils. If wired parallel(appears to be that way) would that increase the spark to the dist.? If no switch is present and they are wired together like that, what is the gain or reason behind it?
One good coil should be better than those two, there was a system here used on racing Holdens, twin coil/twin point ,twin contact rotor button, I dont know if they stole it from GM or came up with it themselves here, they did like to play with cars at Holden (about to move to China) It worked just fine http://holdenpaedia.oldholden.com/L34_Distributor
"That is true, an 8200 would work fine. But a big block in a 37 Ford, pretty much bad ass." It is! lol.
You need to run a MSD coil. A stock coil will not work or even any non CD box coil. I wanted my cool ass finned Judson coil but my truck barely ran with it and the 6A box / magnetic breakerless Accel distributer. I switched to a MSD coil and now performs flawless. Sent from my iPhone using The H.A.M.B. mobile app
Maybe you need any coil, besides a cool ass Judson coil? (the car was running ok with the two coils it had on it, which don't appear to be MSD coils)
Squirrel, you are correct. Car ran fine. I'll update everyone how it runs with the new coil when I get back from St. Louis next week.
When my MSD coil failed for the second time I had a spare Petronix which I installed, works fine with 6AL-2
That's good to know. Speedway has a Pertronix 40501 Flame Thrower on for nearly 50% off so I bought one. Couldn't pass on the pricing.
I'm running a pertronix coil in my Chevy II, but that has a blower on it, and points for an ignition, so it might be like comparing baking and eating apples.
Exactly. I have run hot ignition for years (Jim has too) and I learned that you don't need more coil than you have motor. You don't need to melt the plugs just catch the gasoline on fire. By the way I think that the Frankenstein coil setup is cool, make a good shelf thingy to make people ask questions.
Not true - an MSD 6AL Analog box like he has Will work with a stock coil, it even worked with that mess he had with two coils (which should have had very high resistance and I bet got pretty hot, not to mention the two coils probably didn't spark at exactly the same time). I think in your case Larry it is the Accel Electronic conversion that was causing issues with the stock coil, not the MSD box.
I can bring it to STL on my next trip if you want it? lol You bring up some good points. I'm curious to see how it runs with a conventional coil setup. Allan
Unless you are going to race it, ditch the MSD box, and run the Blaster 2 coil. The MSD box is just something else to give you trouble, when it quits, it quits without warning. Been there done that, paid the tow bill.
