Mount alternator on differential???
Discussion in 'The Hokey Ass Message Board' started by bibb86, Mar 31, 2009.
  1. bibb86
    bibb86
    i was thinking of mounting my alternator like this. what do ya'll think
  2. EnglishBob
    EnglishBob
    Does the alternator going backwards when you reverse not affect anything electrically?
  3. bibb86
    bibb86
    shouldnt be a problem with direction. i only worry about high rpm.
  4. Tman
    Tman
    I think we have about 6 threads about this already. Search
  5. How would the rearend see any higher RPMs than the motor?
  6. Tman
    Tman
  7. bibb86
    bibb86
    i did the search and cant find anything what do i search for. it would create higher rpms cause of the gears in the tranny.
  8. 4dFord/SC
    4dFord/SC
    Maybe not a big problem, but it wouldn't charge at idle.
  9. I guess they work, because I've seen setups like that before. If the pulley is about the same size as a crank pulley, the rpms will be about right when it's in high gear cruising, but spinning pretty slow in lower gears.
    The big problem is that it's not charging when you're sitting there stuck in traffic. Better have a good battery and turn off all the accessories, because everything will be running off the battery whenever you're not moving along.
  10. AnimalAin
    AnimalAin
    Certainly possible, but can't imagine how it is better than driving it off of the crankshaft.
  11. bibb86
    bibb86
  12. Mr48chev
    No charge when the wheels aren't turning and very low charge at anything short of highway speeds.
    As someone else said there are several threads on this but I think it would still be better to tuck it down out of sight on the engine (maybe paint the case engine block color) and have a charging system that would keep the battery up. There are small case high output alternators around that should be easy to keep pretty well out of sight from the casual looker.
    gnichols likes this.
  13. bibb86
    bibb86
    i would be doing it to get a clean look up front no other reason
  14. Pir8Darryl
    Pir8Darryl
    You didn't just really say that did you? :confused:
    LWEL9226 likes this.
  15. oilslinger53
    oilslinger53
    from covina CA
    Overdrive gears- but I wouldn't worry about it unless you plan on running 6000 rpm in you overdrive gear
    the biggest problem is going to be if you get stuck in traffic at night. Also, if it's like my alternator, that doesn't energize until 2000 rpm, it may be a problem in stop and go traffic as well. It's been done, and there are threads on it already. go for a search!
  16. Psychographic
    Psychographic
    I have an 83 S-10 with hydraulic suspension, I used a setup like this to help keep my batteries charged. It worked fairly well, but I would'nt use it as the exclusive way to keep a charge for the car itself.
  17. Da Tinman
    Da Tinman
    I'm going to do the same thing on the shoebox, no way I'm putting an alternator on the flatty.
    I cruised the car for 4 hours with the headlights on (in heavy traffic) before the battery gave up with no charging system at all. Genny failed and no time to fix it before the cruise started.
    Had a spare bat with us for when it quit.
  18. bibb86
    bibb86
    i was also thinking about running a stator off a motorcycle off of my water pump anyone had any experience on this
  19. oilslinger53
    oilslinger53
    from covina CA
    Now that I haven't seen. That's an excellent idea.
  20. Doc.
    Doc.
    I run a setup like that on my '33. I run a second battery with an isolator in case I get stuck for a while in traffic. I've had no trouble with mine. It's not a daily driver though.
    Doc.
  21. bibb86
    bibb86
    i figure i will be running a few lights ignition and an electric fan and thats about it. and now days a new harley will even run HID headlights which use a ton on power so they should run my few electronics
  22. dalesnyder
    dalesnyder
    HID headlitghts have a large draw to start the arc but after they light up they actually draw a lot less than regular lites.
  23. bibb86
    bibb86
    ohh ok i didnt know that.
  24. bibb86
    bibb86
    any comments about the stator idea???
  25. ...
  26. stuart in mn
    stuart in mn
    I recall seeing an ad in Street Rodder some years ago for an alternator that was built into the water pump pulley, it looked pretty similar to what you're proposing. I don't remember the name of the manufacturer, and for whatever reason it seemed like it disappeared from the market pretty quickly.
  27. Pir8Darryl
    Pir8Darryl
    I'v owned a few motorcycles over the years, and hooking them up to the battery charger every weekend is SOP.
    I just cant imagine a [bike] system that's designed to run one headlight, one tail-light, and a starter smaller than an china-man's pecker on a 350cc motor is even going to begin to keep up with a car with A/C, electric fan, 500 watt stereo, 4 headlights, etc, etc, etc, etc.....
  28. Paulz
    Paulz
  29. gnichols
    gnichols
    from Tampa, FL
