This is probably a pointless question. Picked up a Motorcraft starter solenoid since mine went missing off an OT car. Upon removing the solenoid on the metal back plate there is a felt where there is normally either a bump or nothing. Is this merely a vent or does it require a drop of oil from time to time, like on old fan motors that would use a reservoir felt pad to keep the end bearing lubed. It's been a while since the car had an original solenoid so I can't remember if it has the same 'vent' or if this is an engineering update. Box has SW-7663 / B6AZ-11450B / 3303619 Solenoid is stamped Motorcraft D2AF-11450-AA Thanks.
