Or 153, 194, 230, 250, 262, 265, 292, 302, 307, 327, 348, 350, 366, 396, 400, 402, 427, 454, 496, 572.....etc...
Well I did say "etc" I thought 305 &409 but went thru too fast... Remembered 153 at the end. 215... you got me there
Depends on what exact trans you use. For an S-10 trans you can use the plate in this Ebay add and follow his directions eBay item number: 321168494932 Davis Speed is a reliable source that a lot of us use for brackets for our six cylinders. Or use a Jeep input shaft with ten splines and not have the clutch disk issue. https://lugnutz65chevystepside.weeb...ft-swap---diy-and-skip-the-adapter-plate.html There are also the Chevy bellhousings that work with the Ford pattern WC T-5 transmissions. If that has you confused there is a long all inclusive T 5 thread on here with lots of info.
